Old 03-24-2016, 07:48 PM   #1
JoshMonster
JoshMonster's Avatar
Drives: White Pearl BRZ
Does anybody else find the traction control to be too harsh?
I got my 2016 BRZ 2 weeks ago. My previous car was an 08 Honda Civic Si. After driving the BRZ for 2 weeks I've found that I absolutely loath the traction control. In my civic, if the traction control kicked in, it would slightly pull back the throttle just enough to stop wheel spin, but I could continue to accelerate. In the BRZ it completely shuts off throttle and even applies brakes to the rear. Stops me dead in my tracks. Now I'm not trying to do burnouts with TC on. I know how to turn it off. It happens at times where I'm just crusing and have to get on the throttle hard for some reason, and at the first bit of slip, it kicks in way too hard. It even does this in VSC sport mode. I don't mind driving around with TC off, but sometimes I forget. Anybody else feel the same as me about TC?
Pic of my new car.
2016 Crystal White Pearl BRZ: Daily
1970 MGB GT: Project
JoshMonster is offline   Reply With Quote
The Following 2 Users Say Thank You to JoshMonster For This Useful Post:
cwpbrz-ji (03-27-2016), Mr.Impreza (03-25-2016)
Old 03-24-2016, 07:58 PM   #2
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
I always use sport mode to avoid that. Keeps the stability control on but the traction control off.
Kostamojen is offline   Reply With Quote
The Following User Says Thank You to Kostamojen For This Useful Post:
funwheeldrive (03-26-2016)
Old 03-24-2016, 08:35 PM   #3
ryoma
ryoma's Avatar
I have never had TC activate on me while cruising or even flooring it. I'm assuming the reason why it turns on for you is a mix of tires and the road. I have pretty sticky tires and the roads here are pretty decent so plenty of grip to floor it and not spin the tires. I only have had it activate in corners, though I do agree that it is a little bit too easy to activate.
The Following User Says Thank You to ryoma For This Useful Post:
Tcoat (03-24-2016)
Old 03-24-2016, 09:13 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You have an automatic right?
Old 03-24-2016, 09:53 PM   #5
Tor
Tor's Avatar
Drives: Toyota GT86
Yes.
Especially from standstill it's close to being dangerous if you are used to driving with everything turned off. VSC sport isn't any better.
Turn it off, or don't expect the car to move when you need to (and drive accordingly).
Tor is offline   Reply With Quote
Old 03-24-2016, 09:54 PM   #6
JoshMonster
When accelerating in a straight line the reaction from TC is the same in VSC Sport.
I'll give an example. I was pulling out of a parking lot the other day, and right as I entered the highway, a truck in the lot before my lot entered the highway as well. I didn't want to be in this guys way, so I got on the gas a little to make sure I accelerated at his pace or better, but there was a little bit of loose gravel on the ground and my tires barely spun. My car stopped moving until the TC light stopped blinking and by this point my engined RPM dropped, so when I got back on the throttle I didn't have much power. The aforementioned truck got right up on my tail and was not happy that I wasn't moving.
No. 6MT.
Old 03-24-2016, 09:57 PM   #7
JoshMonster
Originally Posted by Tor View Post
Yes.
Glad I'm not alone. I thought something was wrong because I've never had a cars TC react so violently before this one.
Old 03-24-2016, 09:59 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I've had no issues with traction control, even when driving aggressively.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
B-R-Z (03-25-2016), Sarlacc (03-25-2016)
Old 03-24-2016, 10:01 PM   #9
You guys must be driving pretty aggressively on the streets to have it kicking in all the time. It isn't that sensitive and if you are coming to a complete stop because it kicked in the you are doing something wrong.
kch (03-28-2016)
Old 03-24-2016, 10:07 PM   #10
JoshMonster
I drive a little aggressive sometimes. I admit it. I'm not coming to a complete stop, but the car is slowing down A LOT. TC is completely cutting off throttle. It feels like you press your pedal to the floor and the car starts to go for 1sec and suddenly looses power, but your body is still prepared to be moving forward so it feels extremely dramatic. My body literally lunges forward toward the steering wheel.
The Following User Says Thank You to JoshMonster For This Useful Post:
Tcoat (03-24-2016)
Old 03-24-2016, 10:13 PM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I have an auto. For daily driving, i leave the nannies on and have never had an issue with TC kicking in at the wrong time. i drive into work pretty early (around 5:15am) so the streets are quite empty and often times slightly moist with dew, and i take some of the corners quickly. same sequence of corners, day after day, for 23 years now, so it allows me to experiment quite repeatably.
i've had TC kick in for a split second a few times, but only enough to slow the car down a bit in the corner. i have toyo proxes T1 sport tires, which aren't the stickiest. i do notice that the TC doesn't always kick in, even though i feel the rear slipping a bit. it does seem to allow some controlled slippage.
the only times it's kicked in when going straight was spinning the tires on gravel and in the rain (on purpose to see what would happen).
as someone else mentioned, you might just be driving a bit aggressively for the stock tires and road conditions.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Tcoat (03-24-2016)
Old 03-24-2016, 10:14 PM   #12
swarb
are you on stock tires? get rid of them and most if not all the problems will be solved.
Old 03-24-2016, 10:17 PM   #13
JoshMonster
Originally Posted by shiumai View Post
I have an auto. For daily driving, i leave the nannies on and have never had an issue with TC kicking in at the wrong time. i drive into work pretty early (around 5:15am) so the streets are quite empty, and i take some of the corners quickly. i've had TC kick in for a split second a few times, but only enough to slow the car down a bit in the corner. the only times it's kicked in when going straight was spinning the tires on gravel and in the rain (on purpose to see what would happen).
I never said it was kicking in at the wrong time. You and others have said this. I know exactly why it's kicking in. Loose gravel, wet roads, hard shifting into 2nd. It only kicks in when my tires spin. My complaint is that it does too much. It slows my car down too much. Other cars that I've driven (Civic Si, Focus ST, VW GTI) have much more subtle TC. They stop the wheels from spinning, but the car isn't slowed WAY down like my car is doing. Maybe something is wrong with my car. IDK. I've only had it for 2 weeks.
Old 03-24-2016, 10:19 PM   #14
JoshMonster
I am still on stock tires, but I don't see how changing them will effect the TC. If I spin the tires on any tire the TC will still engage. The only thing new tires will help is making it harder to spin them. All tires are spinable though.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction control help carmen.atil Scion FR-S / Toyota 86 GT86 General Forum 4 12-15-2014 11:14 AM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
