Old 07-14-2015, 09:26 AM   #1
customyota
Drives: WRB BRZ
Shrill/harsh tweeters
Hey everyone, I just installed a new set of 2 way components (JBL GTO 609C) and the Alpine KTP 445U to replace the factor doors and fronts, and the tweeters are very harsh. Female vocals are particularly bad. It's pretty unpleasant and fatiguing to listen to after only a few minutes. I've tried re-aiming them so they weren't bouncing off the windshield so much, and I've tried reversing the phasing, but neither helped much. I've searched around various internet destinations, and was looking at getting an L pad to try and attenuate them, but I'm worried that would end up making things muddy since I only have the tweets and the doors, no mid. I've been able to EQ out the worst of it, but I've run out of adjustment. Never thought I'd miss the factor system.
customyota is offline   Reply With Quote
Old 07-14-2015, 01:20 PM   #2
swarb
Have you tried the +3 db/ 0 db adjustment on the crossover box?
Only other idea is to mount the tweeters on the doors.
Old 07-14-2015, 02:55 PM   #3
customyota
Drives: WRB BRZ
Yea, I have it on 0db, but it still sounds harsh. I'd rather not cut holes in the door, so that would be a last resort.
Sent from my Nexus 6 using Tapatalk
Old 07-14-2015, 03:18 PM   #4
swarb
There is an adjustment to boost the sound levels for each signal(radio/cd/bluetooth). I put mine at negative and that helped a bit.
Old 07-14-2015, 03:24 PM   #5
customyota
Drives: WRB BRZ
You're talking about the SVC adjustment, right? I'll give that a try, thanks.
Old 07-14-2015, 03:28 PM   #6
Chimera
Drives: FRS
which head unit are you using? how do you have the amp wired?
Old 07-14-2015, 03:30 PM   #7
customyota
Drives: WRB BRZ
Stock head unit, and the amp is bridged.
Old 07-14-2015, 03:37 PM   #8
Chimera
Drives: FRS
technically your below the safe bridged range at 3 ohms.
Where do you have the gain set?
Old 07-14-2015, 03:41 PM   #9
Chimera
Drives: FRS
As you are below the safe operation range I'd recommend rewiring to standard @45W and see (hear) if it is more acceptable. probably introducing distortion by running the amp outside of its safe zone.
Old 07-14-2015, 05:57 PM   #10
customyota
Drives: WRB BRZ
I'll check it out, the jbl's are advertised as "true 4 ohm" meaning they're actually lower than that to allow for resistance in the factory wiring, but maybe it's causing some issues.
Old 07-14-2015, 11:08 PM   #11
Chimera
Drives: FRS
I have infinity ref x series. Has the same gimmick. I treat it as a 3 ohm. My ktp445u is wired to both front and rear @ 45w/ch
Old 07-20-2015, 01:20 PM   #12
customyota
Drives: WRB BRZ
I just had a random thought about and wanted to make sure I'm not crazy. Since I'm using high level inputs, can I wire the crossover BEFORE the amp? This way i can split the signal and wire the tweets to the amp's front channel and the mids to the rear channel, and I can balance them using the front and rear gains.
Old 07-20-2015, 03:23 PM   #13
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
I don't know much about the speakers you have listed, but I know that on my last build my tweeters were WAY too tinny during the break-in period just as the subs were too punchy. They took around 20-30hrs to finally get them warmed up and evened out. Same went for my Beyerdynamic DT770's, those took over 100 hours and now I wouldn't trade them for the world.
FFT.
edit: Also wiring aside, you might be on to something with trying out different mounting angles.
Special_K is offline   Reply With Quote
Old 07-20-2015, 06:25 PM   #14
Chimera
Drives: FRS
Yes, you could do this. Be careful to not over gain one however.
basically you're making a poor mans active setup.
However, using the eq on your Hu should allow you to do the same thing. I have my 10k on my HU set to 1 tick down, something like -2.5db
Stock Tweeters Available pd Audio/Visual, Electronics, Infotainment, NAV 0 07-31-2013 10:04 PM
New CDT ES-620 6.5" with crossovers + tweeters vinh Audio/Visual, Electronics, Infotainment, NAV 0 07-01-2013 11:52 PM
Need help on tweeters djliquidsteele Electronics | Audio | NAV | Infotainment 3 05-17-2013 08:13 PM
Tweeters that will drop in? SteveGrillo Electronics | Audio | NAV | Infotainment 13 02-18-2013 07:17 PM
