Old 03-29-2016, 10:49 PM   #729
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by Sojhinn View Post
@l0aded how did you tell you were having issues?
My ESC turning off. At first seemingly randomly but I eventually found the pattern.
Basically my batteries got to a point where I could only engage about 50% boost (about 2/3 the pedal) and when I did my voltmeter would drop. Quick. I was hitting 18.0V while holding the pedal at about 2/3 throttle for a few seconds and when it dropped below 18V the ESC would disengage until I released the pedal and re-engaged it. If I tried to engage 100% boost at full throttle the ESC wouldn't even start.
Also, my voltmeter was reading 28.6 or 28.7 at idle. On the new batteries, I'm back to a consistent 28.3V
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 03-29-2016, 10:54 PM   #730
Algreen
Guest
Posts: n/a
Originally Posted by WNDSRFR View Post
You don't need to do anything to condition the batteries. It just happens all by itself. You'll notice an increase in power after a couple days or so after the batteries are "broken in".
Cheers!
Old 03-31-2016, 04:23 PM   #731
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Well, I will finally have my batteries and some plastic bits here by Saturday. So if all goes as planned I will start my ESC install on Sunday. I only mention this, cause if i have any questions I will likely be on here asking for assistance this weekend.
Not that any of you "usual suspects" owe me a damn thing. But, if youre available I would appreciate the help. With any luck, I dont imagine there being any issues. We will see if my soldering was up to the task.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 03-31-2016, 04:25 PM   #732
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
As per the usual. I am always willing to help.
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
FingR-S (03-31-2016), WRB5titch (03-31-2016), zc06_kisstherain (04-03-2016)
Old 04-02-2016, 08:04 PM   #733
stevo585
Drives: White 2014 BRZ
Thinking of trying to put 4 of these with the PC680 in the engine bay. The width would be 15 inchs for all 5.
http://www.sonicelectronix.com/item_...HC600-BLU.html
I just wonder if there will be any performance increase from the extra capacity.
I also what to try to figure out how many amps are be pulled with a multimeter to see if the system is getting its 4000W max. Amps X Voltage = Power (W).
At 22V load that means I need to see 182 A.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 04-03-2016, 07:08 AM   #734
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I only received 1 big crank from battery mart, so the install is on hold.
Daily: Audi TT RS
Old 04-03-2016, 07:42 AM   #735
WNDSRFR
Drives: FR-S,GTI
Don't know where you're going to find a multimeter that will measure 182 Amps. I sure as Hell wouldn't want to be holding it when you make the measurement. That is a dangerous amount of current.
Old 04-03-2016, 08:08 AM   #736
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
How about home Depot? Amps are typically measured with a collar around the wire. No direct contact. Perfectly safe.
Old 04-03-2016, 08:32 AM   #737
WNDSRFR
Drives: FR-S,GTI
That's an Amp Clamp. It only works on AC. To measure DC Amps the meter needs to be in series with the load. That is to say, the entire current is going through the meter. And it's ALOT.
Old 04-03-2016, 08:53 AM   #738
EAGLE5
Dismember
EAGLE5's Avatar
Lots of dc amp clamps available.
The Following User Says Thank You to EAGLE5 For This Useful Post:
WNDSRFR (04-03-2016)
Old 04-03-2016, 12:37 PM   #739
WNDSRFR
Drives: FR-S,GTI
Wow
You're right! They DO have DC Amp clamps that use a Hall Effect Device. Sorry I guess I'm living in the past.
Gotta get up to date.
The Following User Says Thank You to WNDSRFR For This Useful Post:
EAGLE5 (04-03-2016)
Old 04-03-2016, 12:41 PM   #740
Sojhinn
Sojhinn's Avatar
Guys I would recommend staying with Robs recommendations. He has tested several batteries.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
DAEMANO (04-04-2016)
Old 04-03-2016, 04:52 PM   #741
stevo585
I just like to tinker. Rob is also trying to find a cost/performance balance. I'm not. Don't care as much about cost.
Several batteries is good but there are hundreds. He also seems to like battery mart.
I'll have to get my hands on the inductive dc amp clamps.
Old 04-03-2016, 05:46 PM   #742
Sojhinn
Sojhinn's Avatar
Fair enough. Just trying to give warning just in case.
Installed Mods:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
