Old 03-23-2016, 11:29 PM   #71
Ashikabi
Ashikabi's Avatar
Originally Posted by zussypoo View Post
Everything was adjustable enough on Flex Z except caster. That's what every single tech raised as a possible factor as there was no instructions on adjusting caster on their machines.
Have you posted in the local forum for someone to swap coils with? Or someone with stockers you can try?
Old 03-23-2016, 11:30 PM   #72
Kaotic Lazagna
Drives: GR Corolla
How off was your caster after you installed the coilovers? I'm not sure why my passenger side changed ever-so-slightly.
Old 03-24-2016, 12:28 AM   #73
zussypoo
Drives:
We don't really have "locals" in Tucson, and the owners I do know don't have the time to do this. Like I said, this is a time and money issue, and I shouldn't have to be the one doing the testing for another company who can't ship out non-defective products.
The front caster had a variance of about 0.5 to 0.7 degrees after installation of the Tein coilovers.
zussypoo is offline   Reply With Quote
Old 03-24-2016, 12:33 AM   #74
Kaotic Lazagna
Drives: GR Corolla
The caster has quite a bit of leeway for factory specs. What were the toe specs again after the alignment with the coilovers?
Old 03-24-2016, 12:59 AM   #75
Traktor
Drives: Subaru BRZ Limited
T
The factory bolt were put on and it didn't change a thing.
It might not be the bolt, but the negative camber you are gaining from lowering the car which exaggerates the tendency to drift away from oncoming traffic in the absence of appropriate castor adjustment?
Traktor is offline   Reply With Quote
Old 03-24-2016, 01:13 AM   #76
zussypoo
Drives:
I had the tech set toe at 0.03 deg on both sides I believe.
Old 03-24-2016, 01:22 AM   #77
Kaotic Lazagna
Drives: GR Corolla
So if everything was relatively within spec, I can't see why the car would crab to the right.
Old 03-24-2016, 02:33 AM   #78
zussypoo
Drives:
Yeah. We tried many different setups and nothing worked. I just don't understand why it can't be the coilovers' problems.
Old 03-24-2016, 03:59 AM   #79
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
oh shit...should i cancel the order lol ???
I just ordered it few days ago.
FR-Sky is offline   Reply With Quote
Old 03-24-2016, 04:15 AM   #80
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Originally Posted by mav1178 View Post
Depends on the alignment person. Not everyone is a "race professional"...
New Hunter Hawkeye alignment racks have a computerized program w/ instructions on how to adjust alignment on virtually every car made. In the case of my BRZ, when I used the rack there was "no instructions" on how to adjust caster.
Some guys aren't good with communication. OP's alignment guy may be one of them.
-alex
No need to be a "race professional", whatever that's supposed to be. Just need to be a "suspension professional", a pretty important quality to have if your job happens to involve working on suspension...
lukey86 is offline   Reply With Quote
Old 03-24-2016, 07:20 AM   #81
Ashikabi
Ashikabi's Avatar
Shouldn't "have to" but they obnoxiously don't want to try to fix it. So it looks like you're gonna have to figure out out with your own testing to prove it. How much time have you spent getting 4 alignments and going to 6 different shops?
Old 03-24-2016, 09:30 AM   #82
Kaotic Lazagna
Drives: GR Corolla
Not saying it can't be the coilovers themselves, but I just can't figure out how it could be if all alignment specs are within factory allowance.
Old 03-24-2016, 09:42 AM   #83
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Well I think the easiest solution would be for you to just install some camber/caster plates (i know you already have camber plates) and adjust to factory spec and be done with it.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-24-2016, 10:01 AM   #84
cjd
cjd's Avatar
Drives: 2017 BRZ
There only thing off is the caster... Are the top plates perfect mirrors? Can be checked with everything off the car easily. I suppose something could be off at the knuckle mount, but again... Compare of the car easily.
There's something being missed here.
Sway Bar Creaking smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2015 01:28 PM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 12:51 PM
Bc racing v1 coilovers (track spec edition) knocking sounds Tsumari Brakes, Suspension, Chassis 3 08-06-2014 07:44 PM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 06:19 PM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 02:24 PM
