Old 11-12-2015, 11:09 AM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Sway Bar Creaking
I have a Whiteline 20mm front sway bar and every time I go over a bump it makes a creaking sound. I think it's probably the bushings that are making the noise. What's the best way to get rid of the sound? I was going to lube the bushings when I installed it, but it said on the instructions that Whiteline bushings didn't need to be lubed. Kind of confused as to why it sounds like this if that's the case.
smg1138 is offline   Reply With Quote
Old 11-13-2015, 02:07 PM   #2
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Probably lube it and get use to the noise the stiffer poly bushings make
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 11-13-2015, 02:13 PM   #3
fika84
fika84's Avatar
Can't hurt to lube that shit
fika84 is offline   Reply With Quote
Old 11-13-2015, 08:20 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
Just use the right type of lube, so you don't affect the plastic. fwiw Hotchkis suggests a non-lithium based moly grease for their bushings.
Gunman is offline   Reply With Quote
Old 11-16-2015, 12:40 PM   #5
smg1138
smg1138's Avatar
Can anybody suggest a good lube to use on Whiteline bushings? Also, what's the story with teflon tape? I've heard that can get rid of squeaking as well.
Old 11-16-2015, 01:28 PM   #6
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Teflon tape does a great job for sealing pipe threads, and technically it will work on sway bars. It's not the best solution.
Use a dedicated grease (Silicone, Lithium, or Molybdenum Di-Sulfide). Prothane and Energy suspension have their own formulations, which appear to be a silicone w/ PTFE particles suspended in it.
I can't link to a non-vendor site... but there are many suppliers. Even your local auto parts store will have suitable lubes (typically labeled "synthetic brake caliper grease")
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
smg1138 (11-16-2015)
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 12:51 PM
Clutch clicking/creaking Bg8780 Issues | Warranty | Recalls / TSB 4 03-24-2015 11:27 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 06:19 PM
