Old 09-01-2015, 02:37 AM   #169
stockysnail
Just the tip
stockysnail's Avatar
Did the clutch slave cylinder tonight and it's the best clutch mod yet and I've done them all!
Old 10-01-2015, 01:35 AM   #170
stockysnail
Just the tip
Chase Bays stainless steel clutch line installed tonight. Not noticing much if any difference.
Old 01-22-2016, 12:08 AM   #171
stockysnail
Just the tip
Added to the end of the first post with a picture of the Nameless Performance red aluminium ECU bracket & red aluminium pulley covers.
Old 01-22-2016, 01:21 AM   #172
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Be sure to watch your alternator cable for kinking and wear. The lack of cable relief is why I never changed out my di computer bracket. I'm sure it's fine, I'm just an overly paranoid bastard.
Decay107 is offline   Reply With Quote
Old 02-07-2016, 01:29 PM   #173
stockysnail
Just the tip
Removed the Perrin ebrake button and replaced it with a $12 red eBay Chinese button that I like the feel of better than the Perrin.
Old 02-16-2016, 06:17 PM   #174
stockysnail
Just the tip
Couldn't pass up the sale at RallySportDirect on all DeatschWerks products. Got myself 700cc injectors and a fuel pump. I see flex fuel on the horizon mixed with a tune from Vit.
Old 02-16-2016, 06:17 PM   #175
stockysnail
Just the tip
Louvered my hood on Saturday. I still need to get it painted however as the louvered areas the paint flaked off. The paint seems fairly brittle.
Old 02-16-2016, 10:12 PM   #176
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
pics?? obviously it's not painted yet but in for results (before and after)
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 02-16-2016, 11:07 PM   #177
stockysnail
Just the tip
Here you go. Added it to the end of the first post too.
Old 02-28-2016, 02:22 AM   #178
stockysnail
Just the tip
Ordered the TRD momo steering wheel (360mm diameter) today. It's the same steering wheel that comes in the FR-S 1.0 yellow car. I test drove one just to make sure I liked the steering wheel and I loved it so bought it. I'll post some pictures once it comes and I install it.
Old 03-12-2016, 03:55 PM   #179
stockysnail
Just the tip
Added to fist post with a picture:
Gates K061015RB belt added to replace K061010. The K061015 was a little too loose for my liking with the 70mm pulley. The K061010 barely fits. The K061010HD was too tight and didn't fit. The K061015RB seems to be a perfect fit and should last longer and handle the stress of track days a little better.
Old 03-23-2016, 07:00 PM   #180
stockysnail
Just the tip
RCE Tarmac 2 coilovers ordered today. Should be here in the next few business days. Big boy pants are going on! Now I just need big boy breaks in front (AP Sprint).
Old 03-23-2016, 07:17 PM   #181
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Careful with DeatschWerks. I recently bought the DW65C Fuel Pump and it went out on me within 4 days. On the trip to Florida to get tuned it over heated and seized up leaving me with a massive tow bill. Then once on the dyno it was making me run lean on the high end of each gear.
Sent from my SM-G928V using Tapatalk
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 03-23-2016, 07:41 PM   #182
stockysnail
Just the tip
Thanks for the info. Good thing I returned it and decided to do the flexfuel at a later date or maybe never. I'm guessing if I go with the larger Sprintex 335 supercharger, even if I run 92oct, that I'll need to get the fuel pump and injectors even without flexfuel.
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
No Limit's DGM BRZ limited build thread No Limit Motorsport Member's Car Journals 10 05-10-2013 12:09 PM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 12:50 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 12:56 PM
