Old 03-22-2016, 07:37 PM   #1
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
brake rotor need replace?
does it can play one more track day?or i have to replace it? i use dtc60 on track Name:  ImageUploadedByTapatalk1458686257.114544.jpg
Size:  303.7 KBName:  ImageUploadedByTapatalk1458686265.684652.jpg
ZHoward is offline   Reply With Quote
Old 03-22-2016, 07:56 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Looks fine, normal with track use
My AP Sprint rotors look like that
Old 03-22-2016, 07:58 PM   #3
ZHoward
ZHoward's Avatar
ok, thanks!
Old 03-22-2016, 08:45 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Buy a pair of cheap digital calipers and check the thickness too, not just the surface condition.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
cdrazic93 (03-23-2016), Mr.ac (03-22-2016), ZHoward (03-22-2016)
Old 03-22-2016, 09:32 PM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
That's totally fine. Our rotors look ridiculous compared to those.
CounterSpace Garage is offline   Reply With Quote
The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post:
cdrazic93 (03-23-2016), wparsons (03-22-2016), ZHoward (03-22-2016)
Old 03-23-2016, 01:01 AM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, that looks about 1/3 as bad as my rotors did before I replaced them. I also use DTC 60s.
Old 03-23-2016, 01:02 AM   #7
ZHoward
ZHoward's Avatar
so i can still use a lot?
Old 03-23-2016, 01:05 AM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
Yes. I'd defer to what Mike and wparsons have to say, but depending on how hard you push it I'd say you've got between three and ten more track days left on them. And yes, I know that's a big range. It depends on how hard you're driving.
Also, assuming you're not getting a BBK any time soon buy some Togue Factory ducts. Or maybe the Velox ducts I've heard rumors about.
Old 03-23-2016, 01:06 AM   #9
ZHoward
ZHoward's Avatar
ok thanks!!
Old 03-23-2016, 04:07 PM   #10
CounterSpace Garage
You still have life in the rotors. Keep in mind, using brake ducts isn't necessarily the best route to take. Understandably, some people benefit from them without understanding the reason behind them. Different pads react differently with ducting so it has to make sense before going that route. If you have any questions, please don't hesitate to PM us!
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
ZHoward (03-23-2016)
Old 03-23-2016, 04:11 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
ugh ok ill be that guy.
totaled.
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 10:22 PM
Brake duct at rotor location stevesnj Tracking / Autocross / HPDE / Drifting 2 02-23-2016 03:57 PM
Brake Pads + Rotor Mikeez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-01-2015 10:34 AM
Brake Rotor Runout gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-20-2015 01:43 PM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 03:39 PM
