Old 03-21-2016, 04:05 PM   #15
grinerizer
Drives: 2014 Subaru BRZ Limited SWP
whats the point of dual zone in such a small car haha!!
I'm assuming you're not married. Dual zone climate control is a marriage saver. It'll be 90 degrees outside, and if I don't flick her seat warmer on, she starts turning the heat on.
Pain in the ass.
grinerizer is offline   Reply With Quote
The Following 7 Users Say Thank You to grinerizer For This Useful Post:
BRZ_Prague (03-21-2016), g e (03-21-2016), go_a_way1 (03-21-2016), GT86_PRAGUE (04-08-2016), NyC Zn6 (03-21-2016), PandaSPUR (03-23-2016), wreckedrex (03-22-2016)
Old 03-21-2016, 04:08 PM   #16
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Pain in the ass.
ahhhhhh! all makes sense now
Old 03-21-2016, 04:16 PM   #17
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by BD7 View Post
↑↑↓↓←←→→BABA
hum you forgot (select:if playing a 2player game), start nub
fumanchu1 is offline   Reply With Quote
Old 03-21-2016, 04:16 PM   #18
acetothermus
Drives: Flying in a Blue Dream
whats the point of dual zone in such a small car haha!! Just my opinion, I dont really want to start a debate about it But your right, its not hard to flick a switch
Honestly? Bragging rights.
I agree that it's totally pointless. In most cars it is honestly. The only vehicles I'd see it being worth while would be cars with real back seats or even third row seats.
acetothermus is offline   Reply With Quote
The Following User Says Thank You to acetothermus For This Useful Post:
Old 03-21-2016, 04:32 PM   #19
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Not clear which model car the OP has ?? Manually adjustable or Auto climate control ?
I do know that on the manually adjustable, the A/C compressor comes on automatically only in the defog and deice modes of the control modes twist knob.
There's a reason for that. In those modes the drier air (of the 'conditioned' air) hastens the process of removing fog from all windows...and this is done fastest in the fresh air mode (not recirculate).
Additionally, manufactures of cars with a/c want to make sure the a/c compressor does run at times. Running the compressor helps lubricated it's front seal.
The car will get slightly less mpg when the a/c compressor is running.
With the manual control system... you'll have to adjust temperature knob at different settings (to maintain a specific air outlet temperature) depending on whether or not the compressor is running....this is normal.
This car, having a small cabin, fogs up very quickly. That's hastened if there are two people in the cabin. People contribute to the moist air in the cabin. Fortunately this car defogs very quickly, efficiently when the a/c compressor is running, and an appropriate temperature of the temp knob is set. Rear window defogger helps as well, to speed the process.
ToySub1946 is offline   Reply With Quote
Old 03-21-2016, 04:36 PM   #20
ryoma
ryoma's Avatar
don't click auto. hit the AC switch twice if you currently have the fans off. turning on the AC will enable the fans, as well as the AC, then once you turn off the AC the fans will stay on unless you hit off. I have my fan on all the time so I get fresh car flowing. if you have the fan on and turn off the car, the settings save so you basically don't need to touch anything as long as you do not hit the "off" button.
The Following User Says Thank You to ryoma For This Useful Post:
JetSpeed (03-21-2016)
Old 03-21-2016, 04:41 PM   #21
fumanchu1
It's useful when one person is a human furnace and the other a soulless cold hearted ginger
one gets cold air the other hot one
The Following User Says Thank You to fumanchu1 For This Useful Post:
86kahl (03-21-2016)
Old 03-21-2016, 04:54 PM   #22
JetSpeed
Drives: 06' Forester, 15 '3.6 OBW, 16' BRZ
OK, good insight. I only have 100ish miles on the car so it's still new to me. I will give it try next time I start it up.
I WAS turning the HVAC system -completely off- since the weather is so agreeable here lately. Then, when I want the fan on, I could only (seemingly at the time) get it on by selecting AUTO , then turning off A/C. Your work-around is helpful and a great place to start.
Thank You!!
JetSpeed is offline   Reply With Quote
Old 03-21-2016, 04:56 PM   #23
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Not really sure why people are so worked up about this.
1.) A/C helps keep the humidity low in the car, which makes it more comfortable, keeps windows from fogging up, and helps defog windows more quickly.
2.) Occasionally running the A/C compressor keeps it form seizing due to non-use, and helps circulate fluid to make sure hoses and stuff don't dry out. (I don't know if it's true, but I'm told a lot of older cars with knobs used to force you to go through the A/C mode to get to heat when turning on the HVAC because that would give the compressor a kick to keep it from seizing in place.)
3.) If you are worried about acceleration, most modern cars these days automatically turn off the A/C under hard acceleration to give you that little boost in power.
4.) If you are worried about having to recharge the A/C system, or replace the part slightly sooner due to more frequent use, and are willing to disable a feature designed to make the cabin more comfortable for the occupants, maybe you should consider a cheaper car where you can enjoy things like "cool, dry air" without worrying about its effect on your wallet.
Stang70Fastback is offline   Reply With Quote
Old 03-21-2016, 05:00 PM   #24
fumanchu1
Guys, Guys, I think we are losing track of the real subject here and I would like to stop derailing this thread so if we can get back on topic and discuss the konami code it'd be appreciated ok?... thanks for your understanding.
acetothermus (03-21-2016)
Old 03-21-2016, 05:18 PM   #25
acetothermus
The real point I think is why anyone would have a passenger in the twins to begin with? Weight reduction for the win.
Old 03-21-2016, 05:20 PM   #26
fumanchu1
Hum I can think of one reason to have a passenger
Old 03-21-2016, 05:53 PM   #27
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Can confirm firsthand the twins do this. I've actually seen it.
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
Stang70Fastback (03-21-2016)
Old 03-21-2016, 06:19 PM   #28
brz880
Drives: CSB 6MT
Originally Posted by JetSpeed View Post
I have heard that the dealer can re-program the BRZ so that the A/C (read a/c compressor) DOES NOT come on automatically when you turn on the air conditioning system.
Can anyone confirm that this possible and does anyone have the instructions on how to DIY??
Thank You
See http://www.ft86club.com/forums/showthread.php?t=78182
brz880 is offline   Reply With Quote
DTC Codes pleong Software Tuning 12 06-11-2016 01:17 AM
Help - Two Codes Thrown jpit Engine, Exhaust, Transmission 3 04-20-2013 12:52 AM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
What do these accessory codes mean? FastLap Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 05:56 PM
