| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 06' Forester, 15 '3.6 OBW, 16' BRZ
Cheat Codes . . .
I have heard that the dealer can re-program the BRZ so that the A/C (read a/c compressor) DOES NOT come on automatically when you turn on the air conditioning system.
Can anyone confirm that this possible and does anyone have the instructions on how to DIY?? Thank You |
#2 | |
Drives: BRZ and NA
| The Following User Says Thank You to Grimlock For This Useful Post: | go_a_way1 (03-21-2016) |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Up, down, up, left, square, square, R2, L2 is the cheat code for unlimited gas
Down, down, left, left, circle, square, R1, R2 is the cheat code for 221WHP Circle, circle, X, Square R2, L2, square, square is the cheat code for all parts unlocked |
| The Following 23 Users Say Thank You to go_a_way1 For This Useful Post: | 86kahl (03-21-2016), Aozora.BRZ (03-21-2016), Crashdummy (03-22-2016), cwpbrz-ji (03-22-2016), DavidBob (03-22-2016), Djratrap (03-21-2016), Drakiv (04-08-2016), finch1750 (04-08-2016), GT86_PRAGUE (04-08-2016), HunterGreene (03-21-2016), Husker BRZ (03-21-2016), Jfheisenberg (03-21-2016), KevinK121 (03-22-2016), MasonL1997 (03-22-2016), meWant (03-21-2016), mixtape (03-21-2016), p1l0t (03-22-2016), ScoobsMcGee (03-21-2016), shifter907 (03-24-2016), softgrip (03-22-2016), Tectoniic (03-21-2016), Toyarzee (03-21-2016), Vmax911 (03-21-2016) |
Drives: GT86
↑↑↓↓←←→→BABA
I do not like the A/C coming-on automatically when I want heat, cold, etc. everytime I start the car. Sometimes I just want the fan NOT the A/C compressor turning on/off; wears it out in the long-in also. And "no," I did not mean de-froster.
#6 | |
Not Bаnned Anymore
Score 1 FRS score 0 BRZ
| The Following 7 Users Say Thank You to go_a_way1 For This Useful Post: | 86kahl (03-21-2016), finch1750 (04-08-2016), GT86_PRAGUE (04-08-2016), MalcolmHimself (03-21-2016), STV3 (03-21-2016), Toyarzee (03-21-2016), Ultramaroon (03-21-2016) |
Drives: Flying in a Blue Dream
Drives: WRB Subaru BRZ Limited 6MT
The BRZ Limited HVAC system has a toggle switch which allows you to control whether the compressor is on or off. Of course, when you hit the "Auto" button, the car will revert to using the A/C compressor as it helps it do its job more efficiently. The owners' manual explains this pretty well, if I recall.
| The Following 3 Users Say Thank You to theadmiral976 For This Useful Post: |
#9 | |
Not Bаnned Anymore
But your right, its not hard to flick a switch
#10 | ||
There is an option in Techstream I believe, however most dealers will probably scoff at you if you ask for it to be disabled. Any wear would be miniscule if that. You could try getting a techstream cable for $20 then pirating techstream as per the forum guide on here and attempt it even though it is a BR-Z, the only option I remember when I had techstream was definitely Defroster starting the a/c compressor but this is on an FR-S with manual a/c
#11 |
Drives: 1991 Formula Red NSX
| The Following 2 Users Say Thank You to rookie For This Useful Post: | SubaruLifer (03-21-2016), trd87t (04-08-2016) |
#12 |
Drives: '13 SSM BRZ Limited 6MT
I'm annoyed at this also, such a weird thing to do. However I think it's because it starts off in Auto mode everytime and if your last temp settings are lower than what it's reading, it'll automatically turn on AC.
#13 | |
Drives: 10 Series #974 6m/t
#14 |
Boost Creep
Drives: 2016 HyperBlue BRZ
![]() This thread... There's an A/C button. If you don't want it running, push it until the light goes out. |
| The Following 6 Users Say Thank You to Luftwaffel For This Useful Post: | go_a_way1 (03-21-2016), GT86_PRAGUE (04-08-2016), hypebrz (03-23-2016), Jfheisenberg (03-21-2016), NyC Zn6 (03-21-2016), PandaSPUR (03-23-2016) |
| DTC Codes | pleong | Software Tuning | 12 | 06-11-2016 01:17 AM |
| Help - Two Codes Thrown | jpit | Engine, Exhaust, Transmission | 3 | 04-20-2013 12:52 AM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
| Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 03:25 PM |
| What do these accessory codes mean? | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-06-2012 05:56 PM |
