| Northwest AK, ID, OR, WA |
Drives: 2013 Firestorm FRS 6-MT
Portland Area- Rock in motor need advice!
New to the forum. Have searched a lot but just decided to sign up because i need advice from y'all who know this motor before i spend the $$ for the fix.
Long story short went to change my oil Friday. Somehow a rock got in the funnel as i was transferring it to the oil filler and it went right in. So I had the rock sitting on top of the camshaft timing intake gear (if i would have known prior about the camshaft oil control valve i could have got it). Ended up pushing the rock down next to the timing exhaust gear below. Tried removing it through control valve with no luck. It is currently sitting right below the pulley. Between the pulley and the case i would say. Pretty tough angle to get between to scoop it out with anything. I would say i am at the point where i gotta break that case open. Not totally sure what that entails. Going to call around later today to get some quotes. If anyone on here knows a shop in the Portland/Gresham area that is familar with FA20's so i could get an accurate quote that would be appriciated! Weather or not its going to be spendy will be the deciding factor if i take on this project myself or not. Ive got a couple buddies that know motors pretty well but not the FA20 in particular. It would be nice to get input from someone on here that knows the motor real well. Thanks in advance for any input! Kody |
#2 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Total loss. Time to buy a 2017 "86" that will look like ass
| The Following User Says Thank You to go_a_way1 For This Useful Post: | 86kahl (03-21-2016) |
#3 |
Is it possible to get at it with a grabbing tool? Sucks, man. I feel your pain.
#4 |
/scion
Drives: '13 86 M/T
Did they drop the [GT]86?
Edit: Sorry to hear that. Let us know how it got resolved.
"Practice makes better. Only Senna is perfect." - CSG Mike
| The Following User Says Thank You to LOLS2K For This Useful Post: | go_a_way1 (03-21-2016) |
#5 |
Yea I tried using one of the grabbers. It was just too tight to get in
#6 |
How about taping a smaller hose to a shop vac and try sucking it out? I work in Portland and live in Vancouver. Lots of dumb ideas. Sometimes they even work.
#7 |
Tried that as well when it was much higher in the case. Could feel the vacuum effect through the dipstick hole but no luck.
Any ideas help! |
#8 |
Drives: innovate sc frs
Buy my fa20 with a vortech sc.
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
#9 |
If you felt it in the dipstick tube that's too big of a hose. It needs to be about the size of the rock or smaller so the rock sticks to it.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Ammunition (03-21-2016), Jmonty (03-21-2016) |
#10 |
I like to eat!
Get a stiff wire
Place a glob of epoxy on the end of the wire Guide the wire onto the rock Let epoxy set Pull it all out as one |
| The Following 2 Users Say Thank You to Pete156 For This Useful Post: | 86kahl (03-21-2016), Ultramaroon (03-21-2016) |
#11 |
The more I think about your predicament, the more @go_a_way1's suggestion actually makes sense.
I think I'd rather pull the engine and flip it over on a stand before disassembling the timing chain cover. If it doesn't work, you'd still have a nice controlled environment in which you could carefully proceed.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | go_a_way1 (03-22-2016) |
#12 | |
Not Bаnned Anymore
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Ultramaroon (03-22-2016) |
#13 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#14 |
Engine stands are cheap. Stands and shop cranes can be rented. I have both but am in the middle of an Acura TL-sized headache.
| Portland friends.. Need advice on VLESS bumper | tech4pdx | Northwest | 14 | 02-27-2017 12:09 PM |
| Advice needed on removing rock ding on rear fender | babydriver | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 06-26-2015 05:19 PM |
| E85 in the Portland Area?? | Aztec | Northwest | 5 | 03-16-2015 02:02 PM |
| WTB RIms Memphis, Little Rock area | Xdragonxb0i | Want-To-Buy Requests | 1 | 02-25-2014 12:17 AM |
| Need Advice! Stereo for Rock & Metal | Teclis | Electronics | Audio | NAV | Infotainment | 0 | 10-06-2013 10:29 AM |
