Northwest AK, ID, OR, WA
Old 03-21-2016, 02:44 PM   #1
Gbaby86
Drives: 2013 Firestorm FRS 6-MT
Portland Area- Rock in motor need advice!
New to the forum. Have searched a lot but just decided to sign up because i need advice from y'all who know this motor before i spend the $$ for the fix.
Long story short went to change my oil Friday. Somehow a rock got in the funnel as i was transferring it to the oil filler and it went right in. So I had the rock sitting on top of the camshaft timing intake gear (if i would have known prior about the camshaft oil control valve i could have got it). Ended up pushing the rock down next to the timing exhaust gear below. Tried removing it through control valve with no luck. It is currently sitting right below the pulley. Between the pulley and the case i would say. Pretty tough angle to get between to scoop it out with anything.
I would say i am at the point where i gotta break that case open. Not totally sure what that entails. Going to call around later today to get some quotes. If anyone on here knows a shop in the Portland/Gresham area that is familar with FA20's so i could get an accurate quote that would be appriciated!
Weather or not its going to be spendy will be the deciding factor if i take on this project myself or not. Ive got a couple buddies that know motors pretty well but not the FA20 in particular. It would be nice to get input from someone on here that knows the motor real well.
Thanks in advance for any input!
Kody
Gbaby86 is offline   Reply With Quote
Old 03-21-2016, 02:51 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Total loss. Time to buy a 2017 "86" that will look like ass
86kahl (03-21-2016)
Old 03-21-2016, 03:31 PM   #3
Is it possible to get at it with a grabbing tool? Sucks, man. I feel your pain.
go_a_way1 (03-21-2016), Jmonty (03-21-2016)
Old 03-21-2016, 03:40 PM   #4
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Did they drop the [GT]86?
Edit: Sorry to hear that. Let us know how it got resolved.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
Old 03-21-2016, 03:59 PM   #5
Gbaby86
Yea I tried using one of the grabbers. It was just too tight to get in
Old 03-21-2016, 04:06 PM   #6
How about taping a smaller hose to a shop vac and try sucking it out? I work in Portland and live in Vancouver. Lots of dumb ideas. Sometimes they even work.
Old 03-21-2016, 04:13 PM   #7
Gbaby86
Tried that as well when it was much higher in the case. Could feel the vacuum effect through the dipstick hole but no luck.
Any ideas help!
Old 03-21-2016, 07:08 PM   #8
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
Buy my fa20 with a vortech sc.
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
Jonesy86 is offline   Reply With Quote
Old 03-21-2016, 07:11 PM   #9
Any ideas help!
If you felt it in the dipstick tube that's too big of a hose. It needs to be about the size of the rock or smaller so the rock sticks to it.
Ammunition (03-21-2016), Jmonty (03-21-2016)
Old 03-21-2016, 11:17 PM   #10
Pete156
I like to eat!
Get a stiff wire
Place a glob of epoxy on the end of the wire
Guide the wire onto the rock
Let epoxy set
Pull it all out as one
Pete156 is offline   Reply With Quote
The Following 2 Users Say Thank You to Pete156 For This Useful Post:
86kahl (03-21-2016), Ultramaroon (03-21-2016)
Old 03-22-2016, 12:45 PM   #11
The more I think about your predicament, the more @go_a_way1's suggestion actually makes sense.
I think I'd rather pull the engine and flip it over on a stand before disassembling the timing chain cover.
If it doesn't work, you'd still have a nice controlled environment in which you could carefully proceed.
go_a_way1 (03-22-2016)
Old 03-22-2016, 12:48 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Exactly my pattern of thought. As dumb as it sounds it might work hahaha!!
Ultramaroon (03-22-2016)
Old 03-22-2016, 06:14 PM   #13
stockysnail
Just the tip
stockysnail's Avatar
Hopefully we can find all the Hulk-a-maniacs to get them to help flip it since Hogan's probably busy.
Old 03-22-2016, 06:45 PM   #14
Engine stands are cheap. Stands and shop cranes can be rented. I have both but am in the middle of an Acura TL-sized headache.
Portland friends.. Need advice on VLESS bumper tech4pdx Northwest 14 02-27-2017 12:09 PM
Advice needed on removing rock ding on rear fender babydriver Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 06-26-2015 05:19 PM
E85 in the Portland Area?? Aztec Northwest 5 03-16-2015 02:02 PM
WTB RIms Memphis, Little Rock area Xdragonxb0i Want-To-Buy Requests 1 02-25-2014 12:17 AM
Need Advice! Stereo for Rock & Metal Teclis Electronics | Audio | NAV | Infotainment 0 10-06-2013 10:29 AM
