Old 03-17-2016, 01:33 PM   #29
curtdragon
Drives: Acura TSX
The temp is the same as what the ecu sees according to my OBD 2 app
curtdragon is offline   Reply With Quote
The Following User Says Thank You to curtdragon For This Useful Post:
Tainen (03-17-2016)
Old 03-17-2016, 02:11 PM   #30
Rinzler_ft86
Rinzler_ft86's Avatar
Drives: 2013 brz limited edition
What one, they have a few styles. Did you also get the spacer?
I will get a pic of what mine looks like if I get a chance today for you
Nope did not see one with a spacer amazon just had this one.
Sent from my SM-N920P using Tapatalk
Rinzler_ft86 is offline   Reply With Quote
Old 03-17-2016, 02:15 PM   #31
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
This is the one you need. (or this one in gold if you want the thermostat)
Old 03-17-2016, 02:33 PM   #32
Rinzler_ft86
Yeah i got this one. Mishimoto MMOP-TPS Oil Sandwich Plate Adapter with Three 1/8" NPT Port https://www.amazon.com/dp/B004UVL6T4..._bFV6wb6BCR13V
Old 03-17-2016, 02:34 PM   #33
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You can still make it work, contact @Mishimoto and see if they will sell you just the spacer from the oil cooler kit and you should be golden
Old 03-17-2016, 02:52 PM   #34
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by curtdragon View Post
Thanks guys. I'll look again today and maybe get the beatrush one because the Blitz one won't work for what I want... not sure why it only has two ports of the same size
It actually has 3 ports, but only two plugs. Blitz assumes you will run at least one sensor of some type...
Well I think the sensor I have is also 1/8 pt sao it will work. I just thought it looked larger so if I can actually find the Blitz one in the states to order I'll get that.
PM me, I can get you info on it stateside.
-alex
Old 03-17-2016, 03:03 PM   #35
Rinzler_ft86
Already returned it out of frusteration. Also i see another galley plug to tap into from the top of the block i can run oil pressure gauge from
The Following User Says Thank You to Rinzler_ft86 For This Useful Post:
go_a_way1 (03-17-2016)
Old 03-17-2016, 03:04 PM   #36
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
okay, that should work as well.
Old 03-17-2016, 03:05 PM   #37
Rinzler_ft86
And cheaper lol
Old 04-28-2017, 04:15 PM   #38
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Hey Guys - Taking the plunge into this too with the MDX Dual Oil Pressure / Temp Gauge. I Originally bought the perrin sandwich plate too - but ran into the problem of the oil temp sender being too long for that plate.
I do also have the Perrin oil cooler, so i've got a pretty tall stack as it sits.
Any major differences between the TRD and Beatrush as far as functionality? For a $30 price difference what makes the TRD so special, the name?
Or - is it worth buying at all vs just finding galley ports on the engine (Are there 2 available? -if so, where?)
Lastly - has anyone with this gauge done the remote mount of the pressure sending unit? When I spoke to Innovative, they recommended mounting it to the firewall and running a remote line to the oil galley - but what line would that be? Just a braided 1/8 NPT M/F Line? Any help on this would be awesome.
Thanks Guys
This is my setup now:
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
chaoskaze (11-01-2017)
FS: GReddy T518Z Turbo Jefffrs Engine, Exhaust, Bolt-Ons 2 08-15-2014 12:08 PM
Greddy Sandwich Plate 12002802 Captain Snooze Australia Classifieds 2 07-09-2013 07:41 AM
Casting Defect Sandwich Plate Dezoris Issues | Warranty | Recalls / TSB 1 01-22-2013 03:04 PM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
TOYOTA FT-86....SCION! Back off and get your own sandwich! Raiden Scion FR-S / Toyota 86 GT86 General Forum 9 08-07-2010 05:45 PM
