Old 04-12-2014, 07:13 PM   #1
protpibe
protpibe's Avatar
Heads up - Oil sandwich plate
For those of you out there who want to know how to easily tap into the oil system for pressure and temp, here's the easy way!
Order this from Fensport UK:
http://www.fensport.co.uk/Parts/Mode...tegory_16/4696
It's GT86 specific and accounts for the lip around the oil filter seat. I ordered the GReddy sandwich plate but the ports don't clear the rim around where the oil filter sits. This one fits perfectly and also situates the ports so that they will clear the random hoses, lines, and AC compressor.
I mated mine with this:
http://www.smyperformance.com/index....ation-kit.html
Prosport oil pressure sender relocation hose for a WRX. You won't need the galley plug, but the line and mounting bracket will help you move the pressure sender into a spot with a bit more room. You could always make your own, but this came with mounting hardware and a fitting for like $35.
I hope this helps save someone from the same frustrations I had with the GReddy plate!
Old 04-12-2014, 08:00 PM   #2
brz_star21
Drives: DGM BRZ
Sorry to hear you ran into trouble with the GReddy unit but great part referencing.
To add to your informative post, I have the Blitz oil cooler and it comes with almost the same sandwich adapter. The only difference is mine has additional ports on the front for the -10 oil cooler lines. The sensor ports are also there but plugged with sealant until ready to be used.
For those in North America or pretty much wherever, I'm sure any authorized Blitz dealer can get that part or may even stock them. It's #19235 in the Blitz catalog called "Oil Sensor Attachment Type HS". 65mm is listed as the inner spindle diameter. http://www.blitz.co.jp/products/mete...ttachment.html
Excuse the small IG sized pic but you can see my setup has the sandwich plate as high as the oil filler cap...
brz_star21 is offline   Reply With Quote
Old 04-12-2014, 09:51 PM   #3
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I bought the TRD sandwich plate: http://www.japanparts.com/db/parts_d...=28&submit.y=9
Here's a pic from one of the oil cooler threads: http://www.ft86club.com/forums/showp...2&postcount=17
BatStig is offline   Reply With Quote
Old 05-15-2014, 07:09 AM   #4
w3bhead
Drives: A Car
@protpibe, How is the sandwich plate holding up bro? Any leaks? I'm undecided between this and the beatrush oil sandwich plate. The Blitz type HS has 1 o-ring while the beatrush has 2 o-rings.
w3bhead is offline   Reply With Quote
Old 05-15-2014, 01:17 PM   #5
calibrz
Turbo 86
Drives: GT86
nice...put on list.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-15-2014, 01:26 PM   #6
protpibe
protpibe's Avatar
It's awesome, no leaks whatsoever. The GReddy plate also came with 2 o-rings but you're only supposed to use the one that fits the base plate it screws down onto.
The Blitz was zero fuss and no compromises as it was designed for the GT86. The ports are aligned so that the temp/pressure probes won't contact anything around the oil filter. I'm assuming the TRD is similarly designed
Old 05-15-2014, 04:53 PM   #7
Basket Case
Drives: 2013 Raven fr-s
can these be used to create a DIY oil cooler? I have no desire to spend $500 plus when in all reality it is simply a way to tap into the oil system, some lines and AN fittings which I can make, and a small cooler...
Basket Case is offline   Reply With Quote
Old 05-15-2014, 05:50 PM   #8
protpibe
protpibe's Avatar
For that you'll want a mocal thermosystic sandwich plate
Sent from my HTC One using Tapatalk
Old 05-15-2014, 07:53 PM   #9
w3bhead
Drives: A Car
Cool! I'll probably go with your suggestion then. I'm a bit curious however. When you bought the sandwich plate, did it have 1/8 PT or 1/8 NPT threads? The Blitz UK site stated that it's 1/8 NPT but the Japanese website said that it's 1/8 PT. Both have the same part number (19235) though.
Sent from my C6833 using Tapatalk
Old 05-19-2015, 10:15 AM   #10
boomslang
Drives: Toyota
+1, anyone know?
boomslang is offline   Reply With Quote
Old 05-19-2015, 10:34 AM   #11
Hagbard
Hagbard's Avatar
I have the Beatrush plate and it for sure has 2 1/8pt fittings i used for Oil Presure and Temp
t
Hagbard is offline   Reply With Quote
Old 08-17-2015, 05:24 PM   #12
pepe
Drives: gt86
This is compatible?
http://www.ebay.es/itm/D1-SPEC-OIL-F...-/200808027097?
pepe is offline   Reply With Quote
Old 08-17-2015, 09:42 PM   #13
Hagbard
Hagbard's Avatar
Originally Posted by pepe View Post
I don't think so for it to work on the FRS/BRZ it needs to clear the lip that's around the oil filter so it needs to raise the ports up about an inch to clear.
See how these raise the ports up as an example
Old 08-21-2015, 08:18 PM   #14
pepe
Drives: gt86
Thanks .... there may be a cheaper alternative?
FS: GReddy T518Z Turbo Jefffrs Engine, Exhaust, Bolt-Ons 2 08-15-2014 12:08 PM
Greddy Sandwich Plate 12002802 Captain Snooze Australia Classifieds 2 07-09-2013 07:41 AM
Casting Defect Sandwich Plate Dezoris Issues | Warranty | Recalls / TSB 1 01-22-2013 03:04 PM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
TOYOTA FT-86....SCION! Back off and get your own sandwich! Raiden Scion FR-S / Toyota 86 GT86 General Forum 9 08-07-2010 05:45 PM
