| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3011 |
Drives: Frs release series 1.0
Hi guys need some help I have trd lowering springs and just bought rims that are 18x9.5 +35 offset. Wanted to keep the springs for now if possible without scraping and hitting the fenders or suspension. So I need help with what tire sizes will fit. Thanks.
#3012 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
You can also staggef the tire setup to 245/35/18 front and 265/30/18 rear
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | Teseo (03-16-2016) |
#3013 |
Drives: 2016 CBS BRZ
hey I got a quick question, I just tried putting wheels and tires on my 16 BRZ today. So from what I gathered from forum searching was that 245/35r18 would be a good fit all around, so I bought 18x9 +45 Konig integrams and Michelin pss and the tires touched the springs in the front, any suggestions for what to do now?
#3014 | |
#3015 |
Drives: 2012 BRZ, now track car and GRC dai
hi i'm looking at 949 racing 17x8 6UL, offset is +40 and trying to go for a "meatier" tyre look i've gone on a couple of fitment calculators, and have come up with 2 tyre sizes 245/40R17 and 225/45R17, my question is will either of these have rubbing or clearance issues either front or rear?
i'm on stock set up but looking to lower 1" in the future
For a pure sports car, it must be internal combustion-Mazda Motor Corporation’s sports car chief Nobuhiro Yamamoto
#3016 |
Drives: 2013 FRS V1
So I will be running F 18x9.5 -10 and R 18x11 -20 with 15mm spacers all around will I be ok with a 225/40 and R 245/40 and yes the fenders are cut. thanks!!!
or would it be better to run a 255/35 in the rear with out the 15mm spacers?
#3017 | |
Everyone fits RB differently. You could fit either. |
| The Following User Says Thank You to swarb For This Useful Post: | Calais (03-17-2016) |
#3018 |
thanks
#3019 |
Master Member
Drives: Subaru BRZ
2016 BRZ Limited
Looking to get either 17" or 18" Rota DPT in Bronze with Bridgestone Potenza S-04. Still debating if I want stock tire size or go wider on 17's. Or move up to 18's - something like 225 width. Need help with width and offset. I plan to drop the car 1.0-1.2". I believe these were the choices given: 17x7.0 17x8.0 18x8.0 18x8.5 The other choice is 18x8 Rota Tarmac 3 - Sports Bronze(5x100/e48/56.1) Last edited by unplugged; 03-17-2016 at 11:09 PM. |
#3020 | |
8's for 225. Offsets matter, what are the choices? |
#3021 |
Master Member
Drives: Subaru BRZ
#3022 | |
17x9 +35 or 17x8 +22/48 Will all fit. Call if you want a fast response. Otherwise wheeldude is known to be slow with emails. |
#3023 | |
Master Member
Drives: Subaru BRZ
The other wheel is 18x8 Rota Tarmac 3 - Bronze 5x100 e48/56.1 Looks like Rota doesn't even come close to the offsets needed for our cars. Then again, not sure how much 28-32 to 48 offset looks like on the car Last edited by unplugged; 03-17-2016 at 11:28 PM. |
#3024 | |
its all in mm, so +48 is 16mm more "inside the fender" than an +32
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
