#29 | |
Drives: '13 SSM BRZ Limited 6MT
#30 | |
I'd suggest you jack up the car and try to rotate the wheel ...... there shouldn't be any noticeable play in either of the CV joints. However, @tracerit, with your "history",.......... I wouldn't worry about a bad CV joint unless you hear a "clicking" sound, especially in the turns. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | tracerit (03-16-2016) |
#31 |
Drives: 2013 Scion FRS
UPDATE #2
Just got off the phone with the dealer. They said that the axles and boots were fine, no signs of wear and tear, just like I thought. Said that they couldn't find anything related to the noise, they did mention that there was a small noise but it was inconsistent (don't know what that means). They said that the next step is to test drive the car with a technician. I'll mention if they could readjust the e-brakes and see if they could re-torque my axle nuts although I'm fairly certain that they'll charge me for both jobs. |
#32 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
100% axle nuts
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#33 |
#34 |
You tried replacing one side. And tried torquing it yourself... buy new nuts which I'm assuming you already did, take it to a better place than the dealer
NEW CAR!🚨🏎️⛽
#35 |
Dealer will just fuck you over. I had a technician ride with me. He HEARD the clicking and he blamed it on my lowering springs lol. Refused to work on it without crazy charges.
Axle nuts are dirt cheap, and my performance shop I think charged me 40 or 50 to figure out the issue lol Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
#36 |
UPDATE #3
Test drove the car with the technician. He said that it might be a brake slap. I have no clue what this is right now so I'll be doing a bit of research tonight. |
#37 | |
http://www.ft86club.com/forums/showthread.php?t=62324 |
#38 | |
Mine only happened at low speeds, and especially bad when rolling backwards and going up a hill in 1st. It's not a constant clicking, just a click or two here and there. I'm going to stop trying, I did the exact same research you probably have done. I'm trying to help you save time and money lol. The dealer will not help you properly IMO And it is just the axle nuts, replace both and torque above spec and make sure they have that divot in them when they are fully put on
NEW CAR!🚨🏎️⛽
| The Following User Says Thank You to Aztec For This Useful Post: | ft_86 (03-17-2016) |
#39 |
*****PROBLEM FIXED*****
After going back and forth with the dealer, they finally managed to find the problem, a broken TPMS sensor in the rear passenger wheel. I'm not 100% sure that this caused my problem but once they replaced it my noise went away. However, if anyone else is having this problem, I would definitely check the axle nuts and cv joints, as they do tend to go bad, first and then check the TPMS sensor. Good luck! |
| The Following User Says Thank You to ft_86 For This Useful Post: | humfrz (03-25-2016) |
| OEM DRIVER SIDE REAR TOP HAT | OMJM | Want-To-Buy Requests | 1 | 04-25-2016 02:33 PM |
| WTB: rear driver side fender liner | take the cannoli | Want-To-Buy Requests | 0 | 05-13-2015 02:46 AM |
| LOUD TICK-TICK-TICK sound on right hand side | PoRco | Issues | Warranty | Recalls / TSB | 16 | 07-28-2014 12:55 PM |
| Rear driver side clank and click | spyingwind | Issues | Warranty | Recalls / TSB | 11 | 04-04-2014 11:26 PM |
| WTB: FRS rear driver side seat base. | Raven604 | Want-To-Buy Requests | 0 | 09-05-2013 12:23 AM |
