Old 04-24-2015, 04:25 PM   #1
zman
zman's Avatar
Drives: scion frs
Right low beam not working.
Ok so yesterday my hid right low beam went out, so i try to put the oem bulb there but it wont turn on. Also I switched the ballast of the left side to the right and nothing. Does anyone know what the issue might be ? Thanks.
Sorry if this is a double post.
zman is offline   Reply With Quote
Old 04-24-2015, 04:35 PM   #2
Boostedpro
Can't remember off the top of my head but I believe the underhood fuse box has seperate fuses for driver and passenger side headlights. When the bulb/ballast went it may have popped the fuse.
Boostedpro is offline   Reply With Quote
The Following User Says Thank You to Boostedpro For This Useful Post:
zman (04-24-2015)
Old 04-24-2015, 04:58 PM   #3
zman
zman's Avatar
Drives: scion frs
Ok thanks ill try that when I get a chance
Old 04-24-2015, 04:59 PM   #4
zman
zman's Avatar
Drives: scion frs
Also do you know what the fuse is marked as?
Old 04-24-2015, 05:11 PM   #5
Boostedpro
It is labeled as "H-LP RH LO" it should be a 15amp fuse according to the wiring diagram. Don't know for sure if that is how it is labeled on the fusebox though.
Old 04-24-2015, 05:29 PM   #6
kchar
Because Racecar
kchar's Avatar
Drives: 2014 Scion FR-S
Wow this exact thing happened to me a week or so ago. Mine ended up being a blown fuse. It's a blue 15amp for sure. There's a replacement extra already in the fuse box. The back of the fuse cover will show you where it is.
kchar is offline   Reply With Quote
The Following User Says Thank You to kchar For This Useful Post:
Tan (03-14-2016)
Old 04-24-2015, 08:44 PM   #7
zman
zman's Avatar
Drives: scion frs
Ok thanks guys 😀 im glad it's just a fuse because I was about to take it to my dealer lol.
Old 04-25-2015, 01:50 PM   #8
zman
zman's Avatar
Drives: scion frs
All fixed 😊
Old 03-13-2016, 10:03 PM   #9
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by zman View Post
All fixed 😊
Any pics of the fuse think I just blew mine also do we get replacement fuses if so where ?
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 03-14-2016, 01:43 AM   #10
zman
zman's Avatar
Drives: scion frs
We do get replacements, I will try to get a picture tomorrow but it says it on the box where it's located
The Following User Says Thank You to zman For This Useful Post:
SoCal80six (03-14-2016)
Old 03-14-2016, 01:45 AM   #11
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
OK thanks if you can get pics that would be perfect appreciate it!!
Old 03-14-2016, 03:06 PM   #12
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Why would only one side pop a fuse ?
Old 03-14-2016, 07:55 PM   #13
zman
zman's Avatar
Drives: scion frs
Still not home so I couldn't take a picture but this one shows the location of it. 20amp and it's blue.
Old 03-14-2016, 08:08 PM   #14
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Alright thanks bro really appreciate it!!
The Following User Says Thank You to SoCal80six For This Useful Post:
zman (03-15-2016)
Crash Beam afishl1 Exterior Parts (Aero, Lighting, Etc.) 1 04-12-2015 12:51 PM
Hi beam indicator Norkoastal BRZ First-Gen (2012+) — General Topics 4 12-10-2013 12:53 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 03:09 PM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 04:56 PM
Low beam on indicator? percyng CANADA 5 10-10-2012 04:47 PM
