View Poll Results: POLL: What RPM is Your Rev Light Indicator Set To?
7400 RPM 17 18.89%
7300 RPM 3 3.33%
7200 RPM 11 12.22%
7100 RPM 3 3.33%
7000 RPM 22 24.44%
6900 RPM 5 5.56%
6800 RPM 7 7.78%
<6800 RPM 22 24.44%
Voters: 90. You may not vote on this poll
Old 03-11-2016, 04:30 PM   #43
Given that there's probably a few dozen 86's autocrossing every single weekend, bouncing off the rev-limiter down the straight is better than shifting to third or worse lifting off the throttle, we'd know if there were serious issues with hitting the fuel cut multiple times.
Exactly!
Old 03-12-2016, 02:07 PM   #44
mikool
mikool's Avatar
Drives: 14' Firestorm FR-S
I have it set to 7k, I usually shift based on sound and use the indicator as a "don't overdo it bruh" indicator.
mikool is offline   Reply With Quote
Old 03-12-2016, 02:20 PM   #45
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
When the engine cuts off/out, I know I'm surely at the limit.
Shit happens, who cares.
If this car had a heads-up display, as it should, might happen less often. It IS a racecar...right ?
ToySub1946 is offline   Reply With Quote
Old 03-12-2016, 03:31 PM   #46
monkeyslide17
monkeyslide17's Avatar
Drives: frs
I had mine set at 55 but just changed it back to 74 letting the motor rev alil more.
monkeyslide17 is offline   Reply With Quote
Old 03-12-2016, 05:26 PM   #47
GoobyFRS
GoobyFRS's Avatar
Drives: Ultramarine Blue FRS
I think mines set to 6000 but I dont rev that high very often anyways
-GoobyFRS
HRI Tuning ECUTek Tuned - 1320 Performance UEL header - Nameless muffled muffler delete - Perrin CAI - 235/45/17 Firestone Indy 500
GoobyFRS is offline   Reply With Quote
Old 03-12-2016, 05:28 PM   #48
FRed-S
FRed-S's Avatar
Drives: 2015 Scion FR-S
My light flashes around 7400 but I don't have a cut-off as the tune disabled that.
Sent from my XT1254 using Tapatalk
FRed-S
FRed-S is offline   Reply With Quote
rev, rev light indicator, rpm
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
Slip Indicator & ABS light turned on during highway driving... Pwolf Issues | Warranty | Recalls / TSB 24 01-15-2018 11:52 AM
Engine Light On (malfunction indicator lamp) polarstorm Engine, Exhaust, Transmission 0 06-01-2013 11:14 AM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 10:17 PM
Setting rev indicator light video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-09-2012 10:58 PM
