Old 06-09-2012, 08:31 PM   #1
erom
Drives: Scion FR-S Raven
Slip Indicator Light
Hey,
First post is sort of lame but I was driving...perhaps a bit aggressively today...and the Slip Indicator Light came on for a brief second.
I read in the manual that it is a malfunction of the VSC/TSC system...so is it anything to be concerned over?
I thank the more knowledgeable in advance for an answer.
erom is offline   Reply With Quote
Old 06-09-2012, 08:35 PM   #2
Lytheum
Drives: 2013 BRZ Premium 6MT
You probably did something to cause vsc/traction control to step in for a second
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 06-09-2012, 08:45 PM   #3
erom
Yea it was a tight corner and I took it kind of hard. So the light can mean that the system was activated? That would make sense.
I just wasn't sure cause I checked the manual right when I got home and the wording was ' malfunction'...
Old 06-09-2012, 09:01 PM   #4
luxmn
First FR-S
Drives: Whiteout MT FRS
Nothing to worry about. You just got a wristslap by the "nanny" that's all.
luxmn is offline   Reply With Quote
Old 06-09-2012, 10:06 PM   #5
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Congratulations, now go out there and do it again.
At a guess, I would say that if the light is steadily illuminated there's a malfunction, blinking mid-corner just means that the nanny is doing its job.
old greg is offline   Reply With Quote
Old 06-09-2012, 10:06 PM   #6
Lytheum
if those lights are on when you arent doing anything "spirited" it means something is wrong
Old 06-09-2012, 11:11 PM   #7
erom
It was only on for the briefest of moments so, as advised, it must have been the 'nanny'.
Thanks for the replies!
Old 06-09-2012, 11:23 PM   #8
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i love when the nannies actually tuck you around a corner, still learning that limit where it doesnt cut speed but does apply light brake to the inside rear tire and it makes you cut a corner
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-09-2012, 11:34 PM   #9
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Do you have an ultramarine FRS by any chance?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-09-2012, 11:44 PM   #10
carbonBLUE
Reverse Burnouts
nope mines argento!
(wont forget you)
2011 Infiniti G37x
Old 06-09-2012, 11:55 PM   #11
DantKR
Drives: Subaru BRZ LT
It's the: "I'm helping you not loose too much control light since I'm still on light."
DantKR is offline   Reply With Quote
Old 06-10-2012, 01:20 AM   #12
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I want to change my traction control icon to:
ashtray is offline   Reply With Quote
Old 06-10-2012, 01:44 AM   #13
TuxedoCartman
Drives: '13 86
I've actually noticed mine will light up from time to time (usually while doing foolishly sideways maneuvers) even when I've got all the nannies *supposedly* turned off. Kinda curious why that is, and if they're never truly turned all the way off?
TuxedoCartman is offline   Reply With Quote
Old 06-10-2012, 01:47 AM   #14
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by carbonBLUE View Post
nope mines argento!
Ah I actually meant to direct that toward the OP :happy0180:
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 08:33 PM
Torsen limited slip BMWDavid BRZ First-Gen (2012+) — General Topics 41 06-12-2012 09:04 PM
Setting rev indicator light video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-09-2012 10:58 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
