View Poll Results: POLL: What RPM is Your Rev Light Indicator Set To?
7400 RPM 17 18.89%
7300 RPM 3 3.33%
7200 RPM 11 12.22%
7100 RPM 3 3.33%
7000 RPM 22 24.44%
6900 RPM 5 5.56%
6800 RPM 7 7.78%
<6800 RPM 22 24.44%
Voters: 90. You may not vote on this poll
Old 03-11-2016, 01:34 PM   #29
kch
Senior Misanthrope
kch's Avatar
Originally Posted by extrashaky View Post
probably serious. on track i like to shift around 7k as that's peak power anyways. i don't need the extra 500rpm, and that's unnecessary stress on the motor. accordingly, i have my shift light set around 6800 just in case.
Old 03-11-2016, 01:45 PM   #30
g e
OK, so much for the red light. How many times y'all hit fuel cut off in moments of over exuberance?
g e is offline   Reply With Quote
Old 03-11-2016, 01:45 PM   #31
extrashaky
Drives: 2014 BRZ Limited
Okay, that makes sense if he's only driving the car on a track. In traffic he'd never get out of second gear.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (03-11-2016)
Old 03-11-2016, 01:53 PM   #32
til the flashing red light isn't the settable shift indicator
I don't think my shift indicator is set to any rpm, plz add to poll OP
Me neither that is why I say it is set to off. I don't need no stinking light to tell me where I am at. As I have said before when I teach the grandson to drive the car I will be covering the tach so he learns by sound and feel not by reading a gauge. Not like everybody drives the same way and needs to shift at exact revs all the time anyway.
strat61caster (03-11-2016)
Old 03-11-2016, 01:57 PM   #33
Heat Sinker
Drives: 2016 FR-S
It is set at A mere 3200. A nice gentle brake in period
Sent from my SM-G900P using Tapatalk
Heat Sinker is offline   Reply With Quote
Old 03-11-2016, 02:08 PM   #34
If you read the whole break in procedure it says very specifically not to do the same things all the time. Supposed to vary the speed you drive, stay off of cruise and mix things up. Not sure if that applies to shifting as well though but I still shifted at varying revs at break in.
Heat Sinker (03-11-2016)
Old 03-11-2016, 02:08 PM   #35
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
The motor has a 7450 redline but you can't access that so I put it at 7400.
SUB-FT86 is offline   Reply With Quote
Old 03-11-2016, 02:22 PM   #36
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Dozens over the past 3 years and 46k miles, bet some cars have hit hundreds.
ineedyourdiddly
Old 03-11-2016, 02:24 PM   #37
If you listen to some people on here then every single time they shift! At least that is what they will tell you.
Old 03-11-2016, 02:26 PM   #38
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
First lights at 5500, red lights at 7500.
Sequential FTW.
GSpeed is offline   Reply With Quote
Old 03-11-2016, 02:34 PM   #39
Heat Sinker
Drives: 2016 FR-S
I was a little uncertain myself. I cant see the necessity of high 6k+ rpm needed to brake things in. What i do instead is how quickly I get to 60 in the rev range. variable driving style. I'm a grandpa in break in periods.
The Following User Says Thank You to Heat Sinker For This Useful Post:
Tcoat (03-11-2016)
Old 03-11-2016, 02:35 PM   #40
strat61caster
Given that there's probably a few dozen 86's autocrossing every single weekend, bouncing off the rev-limiter down the straight is better than shifting to third or worse lifting off the throttle, we'd know if there were serious issues with hitting the fuel cut multiple times.
ineedyourdiddly
Tcoat (03-11-2016)
Old 03-11-2016, 02:39 PM   #41
I may be confused ........ but, as I thought I understood the question ...... I have the shift light set at 6,500, because it takes me a while to react and I don't like hitting the fuel cut off.
Yes, upon rare occasions, I have hit the fuel cut off ...... because I was having an exceptionally slow day .......
Old 03-11-2016, 04:24 PM   #42
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I meant I shift by 7k. Not at.
1st at 3.5, 2nd at 2.5, 3rd at 6.5k, 4th around 4k and 5 and 6 below 4k
rev, rev light indicator, rpm
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
Slip Indicator & ABS light turned on during highway driving... Pwolf Issues | Warranty | Recalls / TSB 24 01-15-2018 11:52 AM
Engine Light On (malfunction indicator lamp) polarstorm Engine, Exhaust, Transmission 0 06-01-2013 11:14 AM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 10:17 PM
Setting rev indicator light video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-09-2012 10:58 PM
