View Poll Results: POLL: What RPM is Your Rev Light Indicator Set To?
7400 RPM 17 18.89%
7300 RPM 3 3.33%
7200 RPM 11 12.22%
7100 RPM 3 3.33%
7000 RPM 22 24.44%
6900 RPM 5 5.56%
6800 RPM 7 7.78%
<6800 RPM 22 24.44%
Voters: 90. You may not vote on this poll
Old 03-11-2016, 12:02 PM   #15
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by extrashaky View Post
Seriously. How many people actually have the shift nanny turned on?
I think OP has his warnings mixed up and doesn't realize there's a difference between the shift nanny light and the rev limiter warning. Or maybe he really thinks he should shift at 7300 all the time.
I have it to help me make better choices when shifting. I usually shift 7k. I dont want to put unecessary wear on car for no reason. I put mine at 6.5k so i usually shift before now. I use the beep as my 7.4k equivalent.
Old 03-11-2016, 12:03 PM   #16
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
At-least you can hear your beep. I can barly hear mine at 4k rpms
Old 03-11-2016, 12:05 PM   #17
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I need to set my shift nanny light lower lol, I just like having it on when I'm sideways(busy concentrating on the driving more than when/if I should shift because approaching cut-off). allows me to focus a bit more on the maneuver.
fumanchu1 is offline   Reply With Quote
Old 03-11-2016, 12:05 PM   #18
extrashaky
Drives: 2014 BRZ Limited
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
86kahl (03-12-2016), go_a_way1 (03-11-2016)
Old 03-11-2016, 12:06 PM   #19
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Which bear is best?
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
Old 03-11-2016, 12:08 PM   #20
extrashaky
Originally Posted by MokSpeed View Post
Which bear is best?
The Following User Says Thank You to extrashaky For This Useful Post:
Old 03-11-2016, 12:09 PM   #21
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Which bear is best?
extrashaky (03-11-2016)
Old 03-11-2016, 12:09 PM   #22
extrashaky
Old 03-11-2016, 12:15 PM   #23
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
Wow I put mine at 5500 lol
Veloist is offline   Reply With Quote
The Following User Says Thank You to Veloist For This Useful Post:
ethan160222 (03-15-2016)
Old 03-11-2016, 12:16 PM   #24
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
til the flashing red light isn't the settable shift indicator
I don't think my shift indicator is set to any rpm, plz add to poll OP
ineedyourdiddly
Tcoat (03-11-2016)
Old 03-11-2016, 12:44 PM   #25
Trust86
Drives: 2016 Halo FRS
Set mine at 6500, reason: when a corner is coming up and it's close enough, I know I won't have to shift Bc I have the 900 rpms to play with and not lose the tenths of a second shifting and get to stay in the powerband. Why set the shift light at the rev limiter? Defeats the purpose, and our cars don't make much power after 7000 rpm anyways if any
Trust86 is offline   Reply With Quote
Old 03-11-2016, 01:03 PM   #26
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
4.5k,,because if i go all out then I ll have time to react.
FR-Sky is offline   Reply With Quote
Old 03-11-2016, 01:21 PM   #27
MrDinkleman
Drives: 2016 Oceanic, "base" model
I have mine set at 4700 for the same reason. Why the extra 200? Because I find myself almost always upshifting (by feel or by ear) at 4.5k during normal DD driving and the constant beeping was getting annoying.
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
FR-Sky (03-11-2016)
Old 03-11-2016, 01:28 PM   #28
I have mine set to off.
rev, rev light indicator, rpm
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
Slip Indicator & ABS light turned on during highway driving... Pwolf Issues | Warranty | Recalls / TSB 24 01-15-2018 11:52 AM
Engine Light On (malfunction indicator lamp) polarstorm Engine, Exhaust, Transmission 0 06-01-2013 11:14 AM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 10:17 PM
Setting rev indicator light video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-09-2012 10:58 PM
