Old 03-10-2016, 03:54 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
2way coaxial vs component system
So I no that a 2 way in the door only uses the woofer and leaves the tweeter part useless. Am I better off with this and then buying a separate tweeter or a component system with external crossovers like this set?
http://www.jbl.com/car-audio-systems...ystems#start=1
Not sure how well it would work since the doors and tweeters are powered totally separately with the dash Mids in harmony with the tweeters
lbroskee is offline   Reply With Quote
Old 03-10-2016, 04:10 PM   #2
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
How do you plan to power the component set? I'd recommend getting an external amplifier to run them if you go with the comps. To your original question, though, I'd go with components.
kmbkk is offline   Reply With Quote
Old 03-10-2016, 04:12 PM   #3
lbroskee
lbroskee's Avatar
I'm getting the Alpine ktp-445u that every1 seems to love on here. So that leaves me 2 extra 2ohm channels open. But I feel lik I wud b double powering the speakers then
Old 03-10-2016, 05:07 PM   #4
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
Get a pair of 4ohm nominal components, bridge the alpine power pack.
TOOSTUBBORN2FAIL is offline   Reply With Quote
Old 03-10-2016, 05:18 PM   #5
lbroskee
lbroskee's Avatar
So I just realized I need a 3 way to keep everything working properly. Which is getting me back to the cost of OEM audio+ and makin the power pack useless
Old 03-11-2016, 11:45 AM   #6
toast
Drives: 14 BSP Edelbrock BRZ
You do not need a 3 way set. Get 2 way components and an amp; tweets in the dash, drivers in the doors. You can mount the amp and crossovers in the back where the factory amp is and use it's speaker level input for your new amp and the factory amp output wiring for the output from your crossovers, just need to run 2 new lines for the tweeters from the crossovers.
toast is offline   Reply With Quote
Old 03-11-2016, 11:48 AM   #7
lbroskee
lbroskee's Avatar
So disable the dash Mids altogether then since they only work if the tweeter work too (stock wiring)
Old 03-11-2016, 12:13 PM   #8
toast
Yes. They are garbage, as are the OEM tweeters. Pull the mids out and make a mounting bracket for your new tweets to sit in that hole.
Sent from my Nexus 6 using Tapatalk
Old 03-11-2016, 12:16 PM   #9
c4lvinnn
Drives: Toyobaruion
I have focal components up front (6.5 woofer + 1.5" tweeter), and focal 5.25" 2-way coaxials in the rear. JL 300/4, and a JL 10W7 with a JL 500/1. The fronts are all mounted in stock location (with addition of the 6.5" bracketry for the door)
If you're going to get new speakers, do it right and ditch all the OEM crap and do the component fronts with aftermarket amp at the very least.
c4lvinnn is offline   Reply With Quote
The Following User Says Thank You to c4lvinnn For This Useful Post:
toast (03-11-2016)
Old 03-11-2016, 12:27 PM   #10
Chimera
Drives: FRS
This is exactly what I did
Atm I am running ktp 445u bridged powering alpine 60c comps, and then a set of infinity 3.5 with a 200 hz cap in line run off the hu power. I have the alpine scaled back to - 4 dB on the tweeters. I am quite happy with the setup.
Old 03-11-2016, 12:54 PM   #11
lbroskee
lbroskee's Avatar
I wanted 3 way to put actual woofers in the door
Old 03-11-2016, 02:05 PM   #12
TOOSTUBBORN2FAIL
Keep in mind, a simple 2 way is almost alway better than a 3 way unless you have the processing power to tune it. You need at least time alignment for each speaker, and 16 bands of eq per side.
The Following User Says Thank You to TOOSTUBBORN2FAIL For This Useful Post:
lbroskee (03-11-2016)
Old 03-11-2016, 02:07 PM   #13
lbroskee
lbroskee's Avatar
ah ok, makes sense looking at the OEM+
Old 03-11-2016, 02:09 PM   #14
TOOSTUBBORN2FAIL
The tune is what makes the oem+ system get good reviews. The speakers themselves are just ok. But, someone spent the time to tune to this specific vehicle.
FRS Component Out help Votlon Electronics | Audio | NAV | Infotainment 0 09-16-2015 11:14 PM
Would coaxial door speakers plus stock tweeters be too much high frequency sound? Prog Electronics | Audio | NAV | Infotainment 4 12-27-2013 08:15 PM
[WA] Kicker CSS65 coaxial speakers x 4pcs Fizz Australia Classifieds 0 06-18-2013 10:30 PM
Component question Gen Electronics | Audio | NAV | Infotainment 1 11-07-2012 01:55 PM
FRS Fuel System Component Walkthrough DeatschWerks Engine, Exhaust, Transmission 8 09-21-2012 01:09 PM
