Old 02-18-2016, 04:44 PM   #43
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Shutter View Post
Hows the airflow with that setup? I'm debating putting a gauge in that spot, but just concerned about airflow
Originally Posted by solidONE View Post
It's not good, but not terrible. I'm sure a 60mm pod would be a bit worse.
Its actually pretty horrible, but it still flows air. lol
Originally Posted by FRS Johnny View Post
Where are you guys hooking up the oil temp and pressure sensors? I have an oil cooler and was thinking about buying a sandwich plate to go on top of the oil cooler one..
As mentioned there is a specific oil galley plug at the front/top of the block along with a part from subaru that allows for fitment of a pressure sensor (1/8 BSPT thread).
Intent > Content
Old 02-19-2016, 04:06 PM   #44
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Is there a picture of this spot? If this place can be used for oil pressure, is there another one for the temp?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 02-20-2016, 05:43 PM   #45
solidONE
solidONE's Avatar
Ask and ye shall receive.
Here are some photos of the previous set up I installed then uninstalled with a larger oil pressure sender that required it to be relocated, the Subaru galley plug, and a hose to relocate the oil pressure sender.
Gally plug installed into the block:
Original plug vs galley plug with 1/8 BSPT thread fitting:
My prosport setup using the prosport galley plug (1/8 NPT) and the more compact "premium" sender did not require relocation, but is a very tight fit right on top of the galley plug. did not take pics tho.
I'm sure you can rig up some connections to the galley plug for both a temp sensor and a oil sender pretty easily.
Edit: Prosport sender and galley plug. Nice and tidy.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
FRS Johnny (02-21-2016), SPCorBUST (05-07-2017)
Old 02-21-2016, 12:31 AM   #46
FRS Johnny
FRS Johnny's Avatar
Awesome! I will try this out! Hopefully there is enough room there since I have the full blown kit on. I'll get around to this when I do the clutch install. Thank you!
The Following 2 Users Say Thank You to FRS Johnny For This Useful Post:
gdrider77 (02-21-2016), solidONE (02-21-2016)
Old 02-25-2016, 12:09 PM   #47
boomslang
Drives: Toyota
Originally Posted by stevesnj View Post
@boomslang are those TRD gauges?
They are Spek gauges
boomslang is offline   Reply With Quote
The Following User Says Thank You to boomslang For This Useful Post:
stevesnj (02-25-2016)
Old 02-26-2016, 08:32 PM   #48
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Lunatic's set up is the dog's danglies. It would be very cool if some enterprising fabricator would design and market one just like it for 52 and 60 mm gages. I'd love to slip a set of defi oil pressure, and oil and water temps into one of those. I don't track the car, and this would be perfect.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 03-06-2016, 12:36 AM   #49
curtdragon
Drives: Acura TSX
If your gauge needs illumination where did you tap into it?
curtdragon is offline   Reply With Quote
Old 03-06-2016, 01:49 PM   #50
_gt86_user
Inactive
Drives: .
I just followed rallysportdirect instructions on installing the Defi boost gauge with ATI vent pod. Go on the website it has step by step with pics, the rest is just plug and play so you can just use the spots they tapped with.
_gt86_user is offline   Reply With Quote
Old 03-06-2016, 01:50 PM   #51
curtdragon
Drives: Acura TSX
It didn't have anything about illumination. It just skipped that completely
Old 03-06-2016, 02:31 PM   #52
_gt86_user
Inactive
Drives: .
"For the illumination I used the solid purple wire going to the dimmer switch, this will connect to the white wire from the Defi gauge."
I think you were scrolling too fast buddy.
Old 03-06-2016, 04:03 PM   #53
curtdragon
Drives: Acura TSX
Guess so. The way they had it worded
Old 03-06-2016, 08:20 PM   #54
solidONE
solidONE's Avatar
^ you can always use a fuse tap if you're uncomfortable with splicing into your harness. Which is exactly what I did.
Intent > Content
Old 03-06-2016, 08:20 PM   #55
curtdragon
Drives: Acura TSX
Yeah I'm gonna use a tap though I have no issue splicing
Old 04-03-2018, 12:24 PM   #56
srscion
srscion's Avatar
Drives: 2016 FRS
Oil Pressure gauge.
Originally Posted by Lunatic View Post
I made a gauge pod out of aluminum and installed three 2 1/16" gauges. Oil Pressure, Boost, and Tranny Temp. Mine works really well except it's scary how low oil pressure gets at idle.
Do you have a problem with the accuracy of that oil pressure gauge. I have the same gauge and my oil pressure has always read lower than other people that have different brands of oil pressure gauges. Its possible the sensor is ruined because the startup oil pressure exceeds the limit of the gauge and its sensor.
srscion is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
DIY: mechanical oil pressure gauge litemup DIY (Do-It-Yourself) Guides 14 09-06-2014 11:12 PM
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 06:09 PM
