Old 02-14-2016, 06:56 PM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I went ahead and installed a 52mm prosport EVO gauge in a vent pod. While the included wiring and pressure sender coupled with the gauge pod, the prosport oil galley plug and fuse tap made the instal super clean, the LED light is not quite as bright as I would have liked. Kinda wished I went analog with the gauge.
Also the idle oil pressure is scary low at 10-11psi once warmed up..
Intent > Content
Old 02-14-2016, 07:27 PM   #30
http://www.ft86club.com/forums/showthread.php?t=70451
go_a_way1 (02-15-2016), solidONE (02-15-2016)
Old 02-15-2016, 02:37 AM   #31
solidONE
solidONE's Avatar
Exactly like that!
It's not half bad in the dark. Matches some of the lights in the car, kind of.
Matches the door lock and power window switch...
Intent > Content
Old 02-15-2016, 01:19 PM   #32
Originally Posted by solidONE View Post
Exactly like that!
Actually, I've seen @Decay107's Defi gauge. It is fast and has a beautiful display.
I love @Lunatic's setup, too.
Old 02-15-2016, 04:41 PM   #33
solidONE
solidONE's Avatar
Lunatics 3 guage pod looks really clean, but its a bit further from the "line of sight" than I like. Ideally I'd have it mounted to the right of the steering wheel between the cluster shroud/hood and the AC vent. But the vent pod was nice and cheap and it looks clean and easy. I picked the digital readout because I thought it would be easily read. I wasnt expecting it to look so dim in sunlight (which is when I'll be running the car the hardest thus most concerned with my oil pressures).
The defi BF gauge looks like a good match, pricey doe: http://www.defi-shop.com/products/ad...adbf_oilpress/
I kinda wished I went with this one in hindsight: http://prosportgauges.com/amber-whit...ure-gauge.aspx
Yes I'm "frugal" with my mods, but I'm still picky.
Intent > Content
Old 02-15-2016, 04:44 PM   #34
_gt86_user
Inactive
Drives: .
I use the prosport "JDM"series amber/white gauge, was the only one I could find reasonably priced with a sweep/lcd readout. Also would always rather have 60mm gauges.
_gt86_user is offline   Reply With Quote
Old 02-15-2016, 04:53 PM   #35
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Hows the airflow with that setup? I'm debating putting a gauge in that spot, but just concerned about airflow
Old 02-15-2016, 04:54 PM   #36
Trust86
Drives: 2016 Halo FRS
Defi BF series are amazing. they have good features as well. auto dimming, adjust the dimming level, set warnings (controller will make a continuous beep when it hits the set warning temp/pressure), check the highest peak values (oil pressure has 2, highest/lowest), reset the peak values, and also you can record up to 2 or 3 minutes i cant remember which, and you can playback the whole session you recorded and watch the gauges and observe
i had the BF series on my S15 in Japan and bought another set again before i came back to the U.S because once you've had them, you wont buy another brand. Although Greddy is coming out with some new ones as well... they look pretty sexy.
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
Ultramaroon (02-15-2016)
Old 02-15-2016, 10:29 PM   #37
solidONE
solidONE's Avatar
It's not good, but not terrible. I'm sure a 60mm pod would be a bit worse.
Intent > Content
Old 02-16-2016, 10:49 PM   #38
boomslang
Drives: Toyota
boomslang is offline   Reply With Quote
The Following 3 Users Say Thank You to boomslang For This Useful Post:
Lonewolf (02-21-2016), solidONE (02-18-2016), stevesnj (02-17-2016)
Old 02-17-2016, 08:35 AM   #39
stevesnj
stevesnj's Avatar
@boomslang are those TRD gauges?
My 2016 Build thread
Old 02-17-2016, 12:20 PM   #40
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Where are you guys hooking up the oil temp and pressure sensors? I have an oil cooler and was thinking about buying a sandwich plate to go on top of the oil cooler one..
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 02-17-2016, 12:32 PM   #41
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I used the location at the front of the block where the manual specs out the acceptable oil pressure range. I removed the oil pressure switch as it's useless anyway. For temperature, I just use my phone to read from the ECU.
Decay107 is offline   Reply With Quote
The Following 3 Users Say Thank You to Decay107 For This Useful Post:
FRS Johnny (02-19-2016), solidONE (02-18-2016), Ultramaroon (02-17-2016)
Old 02-18-2016, 02:41 PM   #42
Hagbard
Hagbard's Avatar
Sandwich plate for both senors
Hagbard is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
DIY: mechanical oil pressure gauge litemup DIY (Do-It-Yourself) Guides 14 09-06-2014 11:12 PM
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 06:09 PM
