Old 03-03-2016, 08:21 PM   #197
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
That sucks. Can't tell you how many times I've taken my wheels on and off. The ARP studs are nothing short than amazing!
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 03-04-2016, 01:53 AM   #198
bspec
A man
Drives: 14 BRZed
Originally Posted by frs23 View Post
Is this is conclusively saying the ARP studs were bad then, and the root cause is the die was not calibrated correctly or root cause is unknown?
The studs were bad. Die mis-calibration was root cause. Conclusively.
bspec is offline   Reply With Quote
The Following User Says Thank You to bspec For This Useful Post:
frs23 (03-04-2016)
Old 03-04-2016, 11:50 AM   #199
frs23
frs23's Avatar
Drives: FR-S H Lava
ARP should issue a recall then
frs23 is offline   Reply With Quote
Old 03-04-2016, 12:42 PM   #200
qoncept
qoncept's Avatar
Yeah. So, like, are ALL the old studs bad? I haven't had any problems with mine yet. Bought ~June 2013.
qoncept is offline   Reply With Quote
Old 03-04-2016, 12:52 PM   #201
bspec
A man
Drives: 14 BRZed
I'm sure they're not all bad. My bad lot was packaged in November of 2015, and it sounds like they corrected the die in January-early Feb timeframe, but I'm speculating a bit. As for a "start of bad run" date, idk..
Wouldn't hurt for a wholesale customer of ARP to ask the question. @CSG Mike @CSG David?
Old 03-11-2016, 04:45 PM   #202
qoncept
qoncept's Avatar
FYI, I emailed ARP to ask about the studs I bought in 2013:
Hi Jared,
Yes we had a batch at the end of 2015, with some thread issues.
You should not encounter any issues with any purchased in 2013
Thanks,
Sam Benson
Old 03-22-2016, 04:37 PM   #203
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
so I had the same issue.. ordered from amazon... I have these lot numbers:
115566 packaged on 1/02/2015 -- ? (not sure if packaged date is right, hard to read)
112509 packaged on 9/1/2015
116509 packaged on 11/22/2015
117726 packaged on 12/16/2015
*120404 packaged on 2/04/2016*
these work, BARELY. I felt a lot of resistance towards the bottom of the stud even though the lug nut would never make it that far I'd rather have a perfect product than "good enough".
Hope this helps a few people out.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
tato.valverde (06-16-2016)
Old 04-06-2016, 06:25 PM   #204
Dangerboyjohn
Drives: White out 2014 FR-S
I just finished installing my ARP studs. Thanks for the pictures. They were very helpful.
My biggest struggle was separating the hub from the e-brake plate. I ended up threading the bolts into the hub and hammering them to break it free. It always makes me nervous when I use a hammer on my car, but I couldn't find any other way.
All my studs and nuts were a good fit without any binding.
Dangerboyjohn is offline   Reply With Quote
Old 04-06-2016, 11:46 PM   #205
nmastereal
Can you go into more detail on how you separated the hub from the ebrake plate?
nmastereal is offline   Reply With Quote
Old 05-14-2016, 03:17 PM   #206
vidarw
Drives: GT86 High
Is there a good alternative to ARP?
I'm basically looking for a stud and nut solution with higher durability than the OEM?
Do not care about the extra length/racing things.
vidarw is offline   Reply With Quote
Old 06-13-2016, 03:19 PM   #207
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
Tools I'll be needing for this?
Sizes?
Two of my studs broke off, I'm going to be swapping out.
Thank you.
WolF_RS is offline   Reply With Quote
Old 06-13-2016, 03:29 PM   #208
stevesnj
stevesnj's Avatar
From experience i learned that this is the worst way to do this, All you need to do is use the brake adjuster "star wheel" from the front of the hub, loosen and the drum rotor will slide right off.
My 2016 Build thread
Old 06-16-2016, 03:43 PM   #209
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Dezoris View Post
This pile is only 2 years old, only saw one winter 23k miles. Cant get hub apart here. (Rear) Going to have to order new ones. Everything that should be simple isnt.
@Dezoris, how did you solve this?
Old 06-22-2016, 02:02 AM   #210
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
When I did it I had the same issue, one chicago winter about 25k miles. I definitely needed to get a hub puller. Rented it from autozone for about 50 bucks. returned it and got my 50 bucks back after about 10 minutes. it's worth it and save yourself the time for the rear.
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 03:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
