Old 02-28-2016, 07:43 PM   #15
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Just gonna put in my personal experience, albeit its based on my bike and not my car (although I do have coated JDLs coming soon). My pipes started out with a heat shield stock, took them off and got the pipes coated (for looks), put them on and they were still quite hot on my leg, so I wrapped them in DEI wrap, which felt much better, about the same as when the heat shield was on. So if we are talking about "cool to the touch" heat wrap > or = stock heat shield > ceramic coating
I guess I can take some temps in my engine compartment while stock and compare to after I install my headers.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
deuncos (02-28-2016), D_Thissen (02-28-2016)
Old 02-28-2016, 08:01 PM   #16
G-awesome
Drives: 2015 Firestorm Scion FRS
I got the jdl catted headers and didn't bother getting it coated. No over heating issues so far! My car is a DD though with the occasional spirited driving.
G-awesome is offline   Reply With Quote
Old 02-28-2016, 08:19 PM   #17
CCPcoatings
Drives: Dmax
Originally Posted by deuncos View Post
Sorry if this is a noob question, I'm planning on getting the JDL UEL catted headers and was wondering if I should go ahead and get the thermal coating along with it. Seems like the majority of posts I've read all say yes, but is the thermal coating on par, better, or slightly worse at reducing temps when comparing it to the stock heat shield?
The factory heat shield is just that, a barrier to break the radiated heat between the two surfaces. Ceramic coating will do both. It will keep heat inside the pipes and ultimately dissipate heat permeated heat from its surface faster than that of the raw substrate. This is especially helpful with any SS pipes as they retain a lot of heat at their surface.
Best case scenario is coat the pipes and utilize any type or wrap or shield as a back-up if needed.
CCPcoatings is offline   Reply With Quote
The Following User Says Thank You to CCPcoatings For This Useful Post:
Old 02-28-2016, 08:28 PM   #18
CCPcoatings
Drives: Dmax
Ceramc Coating vs Heat Shields
I wonder this very same thing but am afraid to dig out my heat transfer book. Which was the higher priority? I don't think the bellows can be ceramic coated and I also am guessing the ceramic coating is cheaper than a complex assembly.
The bellows is a must for longevity.
No matter what system, the heat has to go somewhere. Maybe the OEM heat shield is more of a heat management sytem. Which heat transfer mode is the most significant? Is it radiated, or convective?
so many questions...
Yes you can coat both corrugated and mesh bellows.....
The Following 4 Users Say Thank You to CCPcoatings For This Useful Post:
BigFatFlip (02-28-2016), deuncos (02-28-2016), D_Thissen (02-28-2016), Ultramaroon (02-28-2016)
Old 02-28-2016, 09:00 PM   #19
Then ceramic coating must not be as effective as encasing the header in a box or it would be the standard. No? It's certainly much cheaper.
Old 02-28-2016, 09:13 PM   #20
redlined600
redlined600's Avatar
Drives: Fr-s
-___-
I assume the oem heat shield is the most effective because that method has been the industry standard for a long time. Not as long as you've been driving, of course. I've seen how they did it back in your day. Museums and stuff.
Heat shields are cheap. I'd put money on ceramic coating, even at the oem cost level, being considerably more than a couple of pieces of stamped metal.
redlined600 is offline   Reply With Quote
Old 02-28-2016, 09:25 PM   #21
There is no way several stamped parts requiring hand assembly with additional fasteners is cheaper than baking a ceramic coating onto a naked header.
Old 02-28-2016, 09:36 PM   #22
CCPcoatings
Drives: Dmax
Depends how you define cheaper. There's a lot more labor and handling involved on thermally degreasing pipes, blasting them, coating them, baking them. then having them installed in such a way that they don't get scratched / damaged along the way. More importantly, doing this in a mass produced manner which is VERY uncommon.
Welding, stamping and most assembly can be done by robots........
redlined600 (02-29-2016)
Old 02-28-2016, 10:21 PM   #23
On a large enough scale, surface prep and finish processes are completely mechanized. None of that is exotic.
BUT... you bring up a very good point about the durability of the finish. Stamped heat shields are assembled once and completely forgotten. How well do the ceramic coatings hold up to the elements?
Old 02-28-2016, 10:31 PM   #24
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
My Fujitsubo catted header coated was at least 20 degrees cooler than the stock one w/ heat shield, as far as engine bay temps were concerned.
Checked w/ a thermal gun.
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
deuncos (02-28-2016), Hostile_Kittens (02-29-2016), humfrz (02-28-2016), Ultramaroon (02-28-2016)
Old 02-28-2016, 11:18 PM   #25
-___-
Now THAT brings on a back-in-the-day story ............
Background (for the young-ens) the old Fords had a "heat shield" that fit over the exhaust manifold and was ducted into the passenger compartment.
I remember, when I was a kid, during the winter, I would sit on the floor of our Model "A" so I could feel the warm air coming out of the hole in the firewall.
If my parents would have had to buckle me into a child seat in the back seat of the car ...... I would have surely froze to death.......
Old 02-28-2016, 11:51 PM   #26
Look at those beautiful castings and that distributor! The lack of need for insulation on the plug leads. Elegant solutions.
humfrz (02-28-2016)
Old 02-29-2016, 08:27 AM   #27
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Honestly we've found the best thing for heat retention/shielding is DEI header wrap, While it has some downsides it works the best for keeping the engine bay cool in our endurance car.
Gear_One_Performance is offline   Reply With Quote
Old 02-29-2016, 08:49 AM   #28
churchx
churchx's Avatar
Drives: 2014 GT86
Imho if it matters that a lot, one can think also of alternatives. For example - installing hood's louvers by TrackSpec from CSG or by Velox from FT86speedfactory. They also help getting temps down.
As for me - imho header's heat insulation need is a bit overblown. Many run without any wrapping, coating or shielding just fine. For track use i'd rather invest into oil cooler rad.
Heat shield on headers winsometang Engine, Exhaust, Transmission 12 05-14-2016 10:58 AM
Tomei uel headers w/o heat shield hahaman86 Engine, Exhaust, Transmission 12 10-29-2014 11:25 PM
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 11:08 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
