Old 11-12-2015, 07:47 PM   #1
winsometang
Drives: Scion F-RS 2013 Asphalt MT
Heat shield on headers
Has anyone tried fitting oem heat shield on aftermarket headers? Or are there aftermarket headers with heat shields that look close to stock?
winsometang is offline   Reply With Quote
Old 11-12-2015, 08:54 PM   #2
Impureclient
Drives: 2015 FR-S
You trying to hide it from the dealer?
Impureclient is offline   Reply With Quote
Old 11-12-2015, 08:58 PM   #3
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Trying to hide the heat from the coil packs?
pushrod is offline   Reply With Quote
Old 11-12-2015, 09:11 PM   #4
imaguitar
imaguitar's Avatar
Drives: Scion FRS - Hot Lava
Why does everyone always want to hide headers & stuff like that from the dealer?
Is it because of warranty stuff?
imaguitar is offline   Reply With Quote
Old 11-12-2015, 09:31 PM   #5
Hawk77FT
Drives: GTS 86
Ceramic coat is your best bet
Hawk77FT is offline   Reply With Quote
Old 11-12-2015, 09:34 PM   #6
jvincent
jvincent's Avatar
If anything an aftermatket header is probably putting less heat into the engine bay since the cat is gone (usually).
That said, I had mine ceramic coated so that there would be even less heat in the bay.
Old 11-12-2015, 09:39 PM   #7
kodyo
Drives: Scion FR-S
I half assed tried with the FT86SF header, as far as I could tell it wasn't even close to fitting. Seeing as he is in Cali, I'm guessing carb legal motivated.
kodyo is offline   Reply With Quote
Old 11-12-2015, 10:45 PM   #8
EzyBrzy
Drives: 2015 WRB BRZ
Probably same thing I'm worried about, warranty/smog(although wont have to get checked for a while)
EzyBrzy is offline   Reply With Quote
Old 11-12-2015, 11:54 PM   #9
winsometang
Yes sir, I've recently had a run in with the lovely authorities and unfortunately was found guilty for having a catless set up... My car just dosent feel the same anymore.
Old 11-13-2015, 08:56 PM   #10
kodyo
Drives: Scion FR-S
I feel for ya, I'm moving to Cali in 2 months and already planning to remove all my aftermarket parts.
Old 11-13-2015, 09:39 PM   #11
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
replace the stock header. Even if you manage to retrofit the stock shield. I dont think you'll be fooling anybody, never mind the authorities that look at these type of cases everyday.
Intent > Content
Old 05-14-2016, 07:03 AM   #12
rx3
There's still no aftermarket header with a heat shield or an aftermarket header where the stock heat shield would fit?
rx3 is offline   Reply With Quote
Old 05-14-2016, 10:58 AM   #13
DAEMANO
Time Traveller
Gut stock header or gut+weld in straight pipe. It works.
Tomei uel headers w/o heat shield hahaman86 Engine, Exhaust, Transmission 12 10-29-2014 11:25 PM
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 11:08 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
WTB: Front pipe cat heat shield Tim_Asphalt_FRS Engine, Exhaust, Bolt-Ons 4 09-19-2013 12:52 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
