Old 10-14-2015, 09:12 PM   #43
w0wbagger
Drives: GT86
Don't know, didn't ask that.
w0wbagger is offline   Reply With Quote
Old 10-14-2015, 09:31 PM   #44
Hawk77FT
Drives: GTS 86
Still debating whether this will make a noticeable improvement on NA. This might be the last thing that will go on before going SC.
Any dyno graphs?
Hawk77FT is offline   Reply With Quote
Old 10-14-2015, 10:22 PM   #45
Naco
Naco's Avatar
Drives: 2015 Steel FR-S MT
Something to keep in mind guys:
The more aggressive the cam is in regards to valve overlap (cleaner combustion = more power), the worse it'll be for boosted applications. It'll also be worse for states with strict emissions.
In regards to the high flowing heads, I believe that might have something to do with the FA20DIT configuration of this motor. The torque that would have been gained from flow velocity when coupled with a twin scroll turbo would have likely caused some reliability issues with the transmission and transfer case.
This then also bring up: Are the cams different on the DIT motor versus ours?
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
Naco is offline   Reply With Quote
Old 01-04-2016, 07:28 PM   #46
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Are there actually any results from these?
hmong337 is offline   Reply With Quote
Old 01-04-2016, 09:44 PM   #47
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Tim Radley View Post
One thing i forgot to add. The camshafts out of my stock 2014 Toyota GT86 measured up differently to the ones Piper had from a 2012 Subaru BRZ. Lift, duration and pin location were all different. It appears there are variations in stock cams between models.
2013 the motors used different 2 intake valves and lifters. In 2014 they use matching intake valves and lifters. Cams are the same so are the rockers. You can verify on Subaru parts catalog.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 01-05-2016, 08:43 AM   #48
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
I've got a high compression big valve motor that we mothballed due to some rule changes, I'm tempted to get a set of the stage 3 cams and throw them in just to see what happens.
Gear_One_Performance is offline   Reply With Quote
Old 01-05-2016, 06:24 PM   #49
stevo585
Drives: White 2014 BRZ
Specs and dyno...please
stevo585 is offline   Reply With Quote
Old 01-05-2016, 11:17 PM   #50
The dyno was unimpressive, we had a bunch of issues with the car at that point and decided to move over to something a little more reliable and tested for the 13 hour race.
Old 02-19-2016, 12:03 AM   #51
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Yes but the stock mapping does not help. I mentioned this elsewhere and a few people piped up and said they'd stalled. Sure you learn to drive around it but my view is the initial throttle opening isn't particularly user friendly. It does make it feel nice and punchy on torque when on the road in a straight line but coming out of slow corners on track it slows you down with the torque spike created. Softening it has made it drive better for me.
Once I put in an after market throttle controller, the initial throttle opening was fixed, The stock mapping for the throttle is horrible!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 02-19-2016, 12:40 AM   #52
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I wonder if their higher stages offer a boosted profile vs NA profile...
Old 02-19-2016, 12:45 AM   #53
Hawk77FT
Drives: GTS 86
You still slow for ficus sake!
Been looking at these Piper cams for a while now, but just want to see if they are really worth anything.
Old 02-21-2016, 07:17 PM   #54
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
For Focus..
I have known about these a long time!
And i am still waiting for you to do something interesting to your car..
Old 02-21-2016, 07:20 PM   #55
Hawk77FT
Drives: GTS 86
For Focus..
Well, buy these and you will finally have a faster (ish) car. Post results afterwards.
Sent from my HTC_0P6B using Tapatalk
Old 02-21-2016, 07:58 PM   #56
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Attachment 131706
No one knows how fast you are when you are hardparked..
The Following User Says Thank You to fuddbutter For This Useful Post:
Hawk77FT (02-21-2016)
Just ordered new Camshafts Fonzi Forced Induction 21 02-11-2018 02:31 PM
Where are all the high lift/duration camshafts! stevo585 Engine, Exhaust, Transmission 35 02-23-2015 06:39 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
does it make a difference at all in hp from an invida over piper compared to motiv Anthony7515 Engine, Exhaust, Transmission 3 04-07-2014 10:26 PM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
