Old 03-25-2014, 08:38 PM   #1
stevo585
Drives: White 2014 BRZ
Where are all the high lift/duration camshafts!
Been almost two years now and no one has developed a performance camshaft for the FA20 yet? Seems like a huge untapped market.
stevo585 is offline   Reply With Quote
Old 03-25-2014, 08:46 PM   #2
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
In never ending development...
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 03-25-2014, 09:13 PM   #3
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I've also started a thread on this topic. There are some out there but the gains for the work don't seem justified yet. I think once we really dial in the best bolt ons and tunes the cam market will start to take off.
Unlike the 15 minute K20 cam change (http://cms.skunk2.com/id/377/15-Minute-K-Cam-Swap/) we basically have to pull the motor to do cams. That's a big deterrent if someone is going to pay to have them put in.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 03-26-2014, 03:37 AM   #4
350matt
Drives: toyota mr2/ Toyota GT86
I think thats the main issue
unless you're prepared to put the revs up and risk blowing the motor then the gains from cams aren't worth the $1500 bill to pull the engine out and fit new items
as best I've seen so far is about 8 bhp from dev cams
and when a supercharger kit gives 80 bhp for $4000 you're better off putting the cash towards that
350matt is offline   Reply With Quote
Old 03-26-2014, 11:43 AM   #5
w00t692
Drives: 2008 Civic Si
BTW, k20 camshafts took a solid 8-10 years to come to the market with stuff that was actually good. It was around 4 years before there was even a camshaft that didn't mess things up and make more power than stock cams.
Bolt-ons also came a LOOOOOOOOONG way in extracting power out of stock cams.
early k20 setups made 220-230 whp WITH cams
Now they make that with bolt-ons and camshafts have moved up to the 240-250 whp range.
You're definitely going to be waiting a while.
w00t692 is offline   Reply With Quote
Old 03-26-2014, 12:13 PM   #6
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I think our best bet is TRD at this point. They are using a set of cams in their griffon car. Hopefully with their budget they figure out a way to make power that other manufacturers can piggyback off.
Cams will always be a big project on this car. I plan to do springs, valves, retainers, balancing and head work when I finally crack the block open to do the cams. Maybe even pistons and rods by then? Higher compression maybe? Who knows at this point.
industrial is offline   Reply With Quote
Old 03-26-2014, 12:57 PM   #7
ML
ML's Avatar
Drives: 13 White MT FR-S
ahh the illusive 250 hp na build
Old 03-27-2014, 12:57 AM   #8
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
BC already has cams developed, already tested on a turbo application. They are now testing it on an NA application iirc
Old 03-27-2014, 09:08 AM   #9
w00t692
doesn't mean they work well. Most people will probably be disappointed with the results of the first few camshafts that come out. I hope not, but it's probably not the case.
Old 03-28-2014, 09:11 AM   #10
SmsAlSuwaidi
Boosted
They work decently, dynos are somewhere around the forum
Old 01-28-2015, 03:12 AM   #11
Jake_86
Jake_86's Avatar
http://www.superstreetonline.com/eve...to-salon-2015/
if case yall still looking
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 01-28-2015, 04:04 AM   #12
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Jake_86 View Post
There is no listing on their website for the FA20 engine
Old 01-28-2015, 04:35 AM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Usually parts come out before the website is updated, atleast from my experience waiting for parts.
Old 01-28-2015, 10:04 AM   #14
celek
Resident Gear Head
celek's Avatar
I have been investigating this subject for about a year.
I know of a few companies working on R&D but no solid results.
Our largest problem is valve to piston clearance. Even with HKS They say you MUST use their pistons with the cams. Probably because with stock pistons you mangle the internals.
I just put my order in for my pistons and allowed for future upgrades with a larger lift and duration. Hoping someone delivers in the near future.
celek is offline   Reply With Quote
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 08:51 AM
Hood lift at high speeds Basti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 97 02-15-2016 03:50 PM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
EZ Car lift RRnold Other Vehicles & General Automotive Discussions 13 11-09-2012 04:20 PM
