Old 07-13-2015, 12:02 AM   #15
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Hey, everyone - I'm the one who sent a message to Piper in post #3, and I just wanted to let everyone know I never got a response from them. I'll update the thread if I do.
Last edited by RJasonKlein; 07-14-2015 at 09:27 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
Ultramaroon (07-13-2015), Valentino (07-13-2015)
Old 07-14-2015, 09:00 AM   #16
celek
Resident Gear Head
celek's Avatar
Originally Posted by RJasonKlein View Post
Hey, everyone - I'm the one who sent a letter to Piper in post #3, and I just wanted to let everyone know I never got a response from them. I'll update the thread if I do.
Talked to them VIA FB last week.
Their web page was down the last few days, maybe server problems.
I will see them at PRI in December.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
RJasonKlein (07-14-2015)
Old 07-14-2015, 09:21 PM   #17
RJasonKlein
Thanks for the heads up - I'll send them the message a second time.
Last edited by RJasonKlein; 07-14-2015 at 09:28 PM. Reason: Corrected a typographical error.
Old 07-14-2015, 09:38 PM   #18
airjonny
airjonny's Avatar
Drives: Nissan Murano
Don't even have the car yet and I'm excited!
airjonny is offline   Reply With Quote
Old 07-17-2015, 01:30 AM   #19
RJasonKlein
Hey, everyone - here's the update we've been waiting for. I got a response from Piper directing me to Tim Radley at Race Developments, who has been working with Piper while developing several neat items for our platform. I sent him an e-mail and here's the response I got from him:
Hi Jason,
I'm running the soft spec cam in my current build. See attached dyno chart. These drive just as a normal car and i'm running a Motec ecu. In fact with the mapping, it's significantly better than stock and doesn't have that torque lurch at low throttle openings that causes many drivers of these cars to stall at junctions. The graph shows the improvement going from stock car to cams, blueprint and exhaust then mapped on Motec. Also that runs the Piper single springs and i'm running the engine to 8000rpm safely for 1500 miles now.
It actually goes a lot better than the dyno chart would suggest. Here is an in-car video doing a launch on a cold day on stock tyres.
[ame="https://www.youtube.com/watch?v=FmbyV4EzqI8"]RD GT86 launch control - YouTube[/ame]
Hits 60mph in 2nd gear but on stock rubber the grip is very poor. I've got some new wheels and tyres to go on in 2 weeks and also some new dampers. I'm confident it will do mid to high 5's to 60 as it is with all that.
Next I will try the 3462/3465 spec cam from Piper along with their dual springs. I think these will add 10bhp more on stock setup but the problem with this engine is the intake manifold. The design is bad.
A lot of people are struggling with this engine to get power, even the race guys when NA. I'm confident it can be good but it requires quite a few parts changing.
I've got everything for a turbo build after and will run a sequential box so there will be lots of development coming off the back of this. I don't want to do turbo until i've proven out the NA stuff a bit more first though.
Also will be looking at a dry sump option too.
Regards
Tim
Tim is actually on this forum, so maybe he can jump in and give us more information as he continues his development work. Lastly, he supplied a picture of the dyno chart, so I'll attach it below.
The Following 16 Users Say Thank You to RJasonKlein For This Useful Post:
-Willis-86touge (12-17-2016), Apexer (07-18-2015), BatStig (07-17-2015), Captain Snooze (07-17-2015), Cesium Rainbow (08-07-2015), civicdrivr (07-17-2015), cyde01 (10-30-2015), hmong337 (07-17-2015), Hyper4mance2k (07-20-2015), Metabrz (07-18-2015), P@ul (07-20-2015), pcuerpo (10-08-2015), steve99 (07-17-2015), swarb (07-17-2015), Turdinator (07-21-2015), Valentino (07-18-2015)
Old 07-17-2015, 01:32 AM   #20
RJasonKlein
Tim also supplied a picture of a header he's working on, so I'll attach it below.
Last edited by RJasonKlein; 07-17-2015 at 01:34 AM. Reason: Corrected a typographical error.
The Following 4 Users Say Thank You to RJasonKlein For This Useful Post:
Apexer (07-18-2015), Hyper4mance2k (07-20-2015), swarb (07-17-2015), Valentino (07-18-2015)
Old 07-17-2015, 01:35 AM   #21
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
8000rpm is fitting for this car.
hmong337 is offline   Reply With Quote
Old 07-17-2015, 02:04 AM   #22
swarb
I would like to know what he means by motor build. Like what else does he have in addition to the cams/springs/exhaust/motec. Header?
Old 07-17-2015, 05:44 AM   #23
swarb
Originally Posted by Tim Radley View Post
One thing i forgot to add. The camshafts out of my stock 2014 Toyota GT86 measured up differently to the ones Piper had from a 2012 Subaru BRZ. Lift, duration and pin location were all different. It appears there are variations in stock cams between models.
The valves are also .7mm longer too, I think it was for the 2015. I forgot where I found that at, but it was a new part number.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Hyper4mance2k (07-20-2015), sw20kosh (07-17-2015)
Old 07-17-2015, 06:12 AM   #24
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
With due respect it is not the car's fault if the driver stalls it.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
hamzam (07-18-2015), Teclis (07-20-2015)
Old 07-17-2015, 06:19 AM   #25
Captain Snooze
Drives: Red Herring
The stock head has way too much flow for the power it's making. Air speed is really bad too. Comparing to some other N/A heads, its making as much flow as ones that do 260bhp so the fact it doesn't make that is down to the combination of other parts.
*raises hand*
Ummm... the FA20 is a new engine and I'm guessing that the crowd who designed the engine would have had their reasons for designing it the way they did.
(This is not a snarky "designers know everything" post.)
What might the reasons be for making the engine the way it is? I'm guessing there is a trade off in there somewhere.
Old 07-17-2015, 06:48 AM   #26
Calum
That Guy
Drives: 2013 asphalt FRS MT
I stripped the engine and blueprinted it using all stock parts except for the cams and springs. I put the head on the flowbench and fixed some issues there too.
I've yet to touch the intake manifold and my feeling is that a problem area. Logging what I do in the ecu I can see several issues going on. When i fix them i'll post up details. Just short of time for the project right now.
Just to confirm, was the dyno on the stock exhaust manifold aswell?
I've been noticing some of your posts around the boards, I'm really excited by what you've been doing.
Old 07-17-2015, 06:52 AM   #27
steve99
Drives: FT86
Hi Jason,
Regards
Tim
Quite amazing that it appears that arround 200whp on a dynojet is the max you get NA
you can get their with cheap headers and E85
or petrol cheap headers and full exhaust
or ultra expensive headers stock exhaust on petrol
or cams head work and likely headers and exhaust as per @Tim Radley
appears something at that power level is holding it back.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Old 07-17-2015, 08:57 AM   #28
celek
Resident Gear Head
celek's Avatar
Flows too much?
This is good news for my 2.3ltr build....
As for the cams with a stock engine what kind of max lift do you think we can use with stock Pistons?
HKS states you have to use their pistons with their cams.
But the only way to get the pistons is with the $5k Stroker kit.
When I had my pistons made I allotted room for 1mm Over valves and a 13mm Lift. I may never use it but it is there.
Sherb (10-07-2016)
Just ordered new Camshafts Fonzi Forced Induction 21 02-11-2018 02:31 PM
Where are all the high lift/duration camshafts! stevo585 Engine, Exhaust, Transmission 35 02-23-2015 06:39 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
does it make a difference at all in hp from an invida over piper compared to motiv Anthony7515 Engine, Exhaust, Transmission 3 04-07-2014 10:26 PM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
