Drives: 2013 White FRS
Just ordered new Camshafts
I just ordered a set of camshafts from Piper Cams. These are a new set of cams not regrind.
Intake Duration : 272 Valve Lift : .472 Exhaust Duration: 266 Valve Lift: .445 |
Junior
Drives: a car
Sounds like fairly mild cams. Probably the farthest you'd be able to run without getting interference.
Yea that was the goal for me. Since 2 of my camshafts were bent instead of buy new stock ones, I went with these.. I dont want my idle all over the place but with some extra up top. They do have a more extreme cam but not what I am looking for
Drives: 2013 Black FR-S
are you forced induced?
Junior
Drives: a car
JESUS how did you bend a camshaft and not throw valves like bullets!?
I am running full blown stage 1 with a gtx2867 ( selling turbo ) need bigger turbo.
Engine build: -Pauter Rods -JE Pistons 9.5 compression -ARP Bolts - Aftermarket Head Gasket Heads -Ferrea +1 MM Exhuast and Intake Valves - Ferrea Dual Spinrgs - FerreaTitanium Retainers -Port and Polish -Five Angle Valve Job -Piper Cams |
| The Following User Says Thank You to Fonzi For This Useful Post: | WORKS (02-12-2018) |
#10 |
Drives: DGM BRZ Limited
12mm on intake and 11.3 exhaust. Have you done any measurements for static overlap? I do wonder if 12mm is possible on exhaust. For your turbo size it seems pretty good. BTW are these measured at .010 valve opening?
#11 |
My turbo size will be going to a gtx3076 or gtx3582.. The measurments are done at 110 degree nominal and has a 49 degree overlap.
| The Following User Says Thank You to Fonzi For This Useful Post: | Coheed (04-05-2015) |
#12 |
Add lightness!
Drives: 17' WRX
Who are you using to build your engine? I'm probably going to go that way in a year or two.
#13 |
Sideways and Smiling!
Drives: Scion FR-S
Go with gtx30. gtx35 may not hit peak boost till 5k rpm and unless you wanna make a drag monster with over 650whp its not worth it.
#14 |
| The Following User Says Thank You to Fonzi For This Useful Post: | industrial (04-04-2015) |
| Where are all the high lift/duration camshafts! | stevo585 | Engine, Exhaust, Transmission | 35 | 02-23-2015 06:39 PM |
| WTB: CAMSHAFTS urgent! | Ondreiko | Want-To-Buy Requests | 0 | 09-25-2014 01:17 AM |
| CAMSHAFTS! have they made any? | karma003 | Engine, Exhaust, Transmission | 21 | 11-04-2013 07:35 PM |
| Have you ordered your FRS? | MrFRsLa | Southern California | 10 | 05-16-2012 01:13 PM |
| FR-S pre-ordered ! but ... | QC-FRS | CANADA | 11 | 04-20-2012 01:53 PM |
