Old 02-18-2016, 05:06 PM   #1
tskaohu
tskaohu's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWS
Fuel trims are f***** up
Hey guys,
i have been working on scaling my MAF due to the injen intake that i have installed. as ive been logging ive noticed stft's and ltft's as high as -19% during highway driving and higher than -20% on just basic idle. I have no clue as to why this is happening. I used @vgi utility to scale and loaded up that scale yet my trims are still fucked. Any advice? what the fuck should i do lmao.
1320 Performance Headers & Overpipe | HKS Hi-Power Spec-L Catback Exhaust | Delicious Tuning Flex Fuel Kit | Delicious Tuning Stage 2 Tune | Tein Flex A Coilovers | 20 & 25 MM Spacers
tskaohu is offline   Reply With Quote
Old 02-18-2016, 05:39 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
1. Take intake off and throw in bin.
2. Don't mistake me as joking.
If you've used one tool a total of one time, you've probably gone backwards btw.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
FRSBRZGT86FAN (02-18-2016), wparsons (02-19-2016)
Old 02-18-2016, 05:40 PM   #3
tskaohu
tskaohu's Avatar
Everyone has told me that😂. I will definitely. Do that. Metal tubing=horrible heat soak?
Old 02-18-2016, 06:48 PM   #4
86Tony
Drives: 2015 AOZORA EDITION
just sell the intake and get a drop in which has been proven to make gains. now a days oem intake are so well designed that puttin a intake on some platforms have lost power
86Tony is offline   Reply With Quote
Old 02-18-2016, 08:05 PM   #5
swarb
Originally Posted by tskaohu View Post
Everyone has told me that��. I will definitely. Do that. Metal tubing=horrible heat soak?
Yes heat soak. Yes horrible. First run and last run will run so different it will throw all your readings/adjustments off. There was another brand that sold a black metal version of the intake tube and no one speaks of them anymore.
What fuel are you running? e85? any e10/gas in it? From my experience full e85 is on the + side for LTFT, this is for the stage 2 uel e85 oft tune.
Old 02-19-2016, 08:28 AM   #6
Ashikabi
Ashikabi's Avatar
I heard an intake mid doesn't require maf scaling on this platform. I dunno, just passing that on
Old 02-19-2016, 08:44 AM   #7
wparsons
wparsons's Avatar
^^ That totally depends on which intake. Most intakes on this platform absolutely require MAF scaling to be redone.
For the OP... how many logs do you have, and roughly how many minutes (or hours) of driving do they cover? Under what kinds of conditions? You need a solid hour+ of logs to properly redo the MAF scale under various conditions. You'll need some WOT pulls from low RPM to redline, light throttle across a wide RPM range, etc.
flickr
Old 02-19-2016, 09:39 AM   #8
Ashikabi
Ashikabi's Avatar
Good to know. Thanks for correcting me. I saw you used arrows instead of quote. Do you know how to use the quote function? I didn't for a long time. Just trying to be helpful
Old 02-19-2016, 04:10 PM   #9
phrosty
Unless your MAF table is realllly off (which is possible, don't know how that intake works), -20% is something I'd expect to see if you're running an E85 tune but 93 gas.
phrosty is offline   Reply With Quote
Old 02-19-2016, 08:36 PM   #10
Lonewolf
Lonewolf's Avatar
Drives: Moped
Hey guys,
Yup, get a drop-in filter instead and get tuned by Bill at Delicious...things should be much better by then
Old 02-19-2016, 09:06 PM   #11
tskaohu
tskaohu's Avatar
That is my plan. I'm taking my intake out and putting stock back. The. Going delicious ahah
Old 02-23-2016, 09:53 PM   #12
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Is your Adv. multiplier staying up at 1?
I only ask because I recently put 87 in my tank because they mis-labeled it and my trims and adv went crazy. Had to revert to a petrol tune.
Hey guys,
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
MGPAX is offline   Reply With Quote
Possible vacuum leak? (Running lean and high fuel trims) nickw14 Engine, Exhaust, Transmission 6 02-10-2023 10:56 AM
Extremely jumpy short term fuel trims all of a sudden silverbullet Software Tuning 5 02-17-2016 04:31 PM
Sudden high fuel trims - help please! cawith Issues | Warranty | Recalls / TSB 13 10-15-2015 04:30 PM
Fuel trims abnormal after cleaning intake. feldy Engine, Exhaust, Transmission 8 04-16-2014 04:48 PM
Fuel trims video mike_ekim1024 Software Tuning 1 12-20-2013 08:01 AM
