Old 02-16-2016, 06:26 PM   #1
silverbullet
Drives: 2013 BRZ LTD Silver
Extremely jumpy short term fuel trims all of a sudden
I have been running stage 1 on the OFT for about 50k miles without issue and then over the course of the last couple weeks have watched my fuel trims in closed loop get progressively worse. At steady state partial throttle I'm seeing anywhere from +11 to -11 over the course of just a second or two (I have the maf scaling pretty dialed so normally I never see over 2%). I have gone through 3 tanks of gas from different stations and have checked the intake track for possible vacuum leaks. Only mods are a perrin inlet tube and a catback. I'm thinking mabey the 50k of running rich on a tune has killed the o2 sensor? Idk, any ideas would be greatly appreciated.
silverbullet is offline   Reply With Quote
Old 02-16-2016, 07:46 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
It could be your intake, but I see the same thing on my stage 2 tune. I've been told to ignore STFT as long as LTFT looks good. I think that STFT may be tip in enrichment or something of the sort.
JB86'd is offline   Reply With Quote
Old 02-16-2016, 08:30 PM   #3
silverbullet
Unfortunately it is affecting the LTFT as well and causing knock. DAM dropped to .45 today =\
Old 02-16-2016, 10:06 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
What are your LTFT sitting at?
1974 TA22 Celica
2013 86 GT
Old 02-16-2016, 10:46 PM   #5
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
2.xx Stg1 maf scale is similar to stock and AFR won't ever be under 11.6 provided you're running at least version 2.00 and not 1.59.
Old 02-17-2016, 04:31 PM   #6
silverbullet
LTFT ranges from -8 to +5. I am running 2.xx tunes but I have flashed back to stock and I am seeing the same issues with fuel trims but slightly worse than on the stg 1 tune. On the stock tune I was seeing LTFTs of -10 at idle and STFTs anywhere from -15 to +15 under partial throttle.
Sudden high fuel trims - help please! cawith Issues | Warranty | Recalls / TSB 13 10-15-2015 04:30 PM
Negative Short term fuel trims at idle w/ no obvi leak IBill4You Forced Induction 21 05-29-2015 09:49 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
