#15 |
Drift noob
Drives: 2015 BRZ Sport-Tech CWP 6MT
Theres a fellow in the GTA selling a set of pro kits with stock struts for 300. Check Can classifieds.
FT86Z
藤原とうふ店 |
#16 |
Drives: 13 FRS
#17 |
Drives: 2015 CWP BRZ Limited
#18 |
Drives: 2013 BRZ, SSM, Limited, M/T
OP you have a PM
Shameless plug: I have both stock struts (14k miles) + pro-kit springs for sale $250 and Koni yellow single adjustable shocks (18k miles) + pro-kit springs for $700 I've loved both setups and now I'm moving up to fully adjustable coilover setup for DD/track duty If you're interested let me know. Thanks =) -Bret |
#19 |
Drift noob
Sorry I read the post wrong, they are indeed Sportlines and jawn makes a good point
FT86Z
藤原とうふ店 |
#20 | |
Drives: '13 FRS - STX
#21 |
Drives: 2013 WRB BRZ 6MT
I believe the replacement interval of 60k refers to miles so around 100kkms? I've got around 30kkms and I'll be selling them in the spring once my coils are on.
#22 | |
As for what parts, I would replace the upper mounts and bearings as well.
#23 | |
Dampers fail before 50k, after, and right on the dot. Anybody who cares can either afford to replace low end dampers wholesale or have them rebuilt (bilstein's are ~$450 last I checked, and can be revalved if desired) or at the least afford some dyno time to do a health check. Personally, I wouldn't even think twice about running the OE dampers to >100k miles provided they don't show signs of failure, most road cars sail past that without any deterioration in ride quality. (fwiw my OE dampers with >40k miles on them are perfectly healthy)
#24 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#25 |
6x track days, ~10x autox events
So less than 1k track miles, but imo that's irrelevant, the dampers will get more of a workout on shitty freeways in ill repair (For anyone in the bay my car has seen probably 20k miles on 101/280/680/80) than on a smooth track. Edit: Mav put more track mileage on his Ohlins and they dyno'd well at 20k miles: http://www.ft86club.com/forums/showp...&postcount=212 |
#26 | |
Not Bаnned Anymore
#27 | |
| Airlift performance air struts (only struts) | RavenFR-Sowner | Brakes, Suspension, Chassis | 1 | 11-01-2015 04:51 PM |
| FS: Stock Struts | continuecrushing | Brakes, Suspension, Chassis | 0 | 01-08-2014 04:04 AM |
| WTB: OEM struts | KVDB31 | Want-To-Buy Requests | 4 | 09-08-2013 09:32 AM |
| Slotting Struts | ML | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 05-24-2013 03:08 PM |
| JDM BRZ Struts different than USDM BRZ Struts? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-30-2012 10:21 AM |
