Old 02-15-2016, 03:02 PM   #1
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Buying Pro Kit - need new struts
Hey guys, i'm gonna bite the bullet and finally give my car a nice little drop this spring.
I'm at 60k, so i'm not gonna risk installing the eibach pro kit springs on my current struts.
I was looking at the toyota OEM parts and found this:
Is part #1 (the strut/shock) the only the part I need to buy for my mechanic in order to install the springs?
If i'm thinking correctly, buying new shocks and struts should increase the lifespan of my springs right? i'm hoping to get at least 1 year out of them
RickyRacer is offline   Reply With Quote
Old 02-15-2016, 03:09 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
yeah #1 is just the strut itself. Honestly buy slightly used ones off another member here. You can get them dirt cheap and in great condition
Old 02-15-2016, 03:10 PM   #3
HachiRo
Drives: 2013 White-Out FRS
In for answers also. About to install springs on 54k miles. If anyone is selling low miles struts:shocks, lmk!
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 02-15-2016, 03:11 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
http://www.ft86club.com/forums/showthread.php?t=101600
comes with swift springs too, those are really good springs lol. you can thank me later
Old 02-15-2016, 03:21 PM   #5
HachiRo
Already got the springs I've wanted but damn that's a great price. OP if you don't have Pro Kit yet, jump on that deal!
Old 02-15-2016, 03:22 PM   #6
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
I'm from Canada... would probably cost a fortune to ship
Plus i like the reassurance starting from brand new struts..
Old 02-15-2016, 03:24 PM   #7
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Have you thought about just getting Konis or Bilsteins? It's like 100 dollars more than buying a new set of OEM struts.
jawn is offline   Reply With Quote
Old 02-15-2016, 03:26 PM   #8
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Not sure if his are still available, but his are in mint condition! Only 8000Km and price is good. Good guy too!
http://www.ft86club.com/forums/showthread.php?t=94665
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 02-15-2016, 03:37 PM   #9
Nickosport
Drives: 2015 WRB BRZ Premium
Isn't the suggested change interval for the OE struts something like every 40k or 60k miles?
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 02-15-2016, 04:08 PM   #10
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
i would prefer OEM, personally
thanks pal! didn't dig that deep into the classifieds. will check to see if theyre still available
this is exactly why the time is now to buy the pro kit my struts will be needing replacement soon anyway
I figure why not give it a shot... I read the pro-kit thread and people are extremely pleased with the drop and the ride quality
Old 02-15-2016, 04:28 PM   #11
Teseo
Drives: frs
Make sense to buy all new struts, alignment in one stop. Do it right and do it once
Old 02-15-2016, 05:09 PM   #12
strat61caster
strat61caster's Avatar
Source on OE struts needing replacement at 60k? That sounds absurd to me, most OEs claim they're for life and even under hard use easily hit 150k miles and decades of use if made well and not leaking.
There's zero alignment capability of stock struts, pretty sure you could swap in 5 different sets and never get an alignment more than a tenth or two out of spec. Spring height difference could make a change to toe worthwhile but there's nothing else you can do to compensate unless you add spring spacers.
ineedyourdiddly
Old 02-15-2016, 05:29 PM   #13
jawn
jawn's Avatar
Needing replacement is a matter of perspective. The internal seals in a strut can and will degrade given enough miles. This can occur without the strut leaking from the body, and it's fairly gradual. 60K is a number that's thrown out there, but you can certainly stretch it longer than that.
Most people only notice that their struts are bad when they're completely blown, since it's a gradual change. That said, I've seen OEM struts completely fail as early as 50K, but that was in a car that lived on fairly rough roads. Depending on your expectations for damping, it's not a bad idea to replace them before they completely fail. I've seen 60K mentioned a lot, but I generally think of anything described by manufacturers as being a "lifetime" interval item needing to be inspected or serviced between 50K and 75K. If you don't care that your dampers aren't performing like new, you can ride it until they're completely blown.
Old 02-15-2016, 05:42 PM   #14
jawn
jawn's Avatar
For reference:
[ame="https://www.youtube.com/watch?v=2rzDKFy3YII"]SACHS Shocks Your Car - the When and Why to Replacing Shocks - YouTube[/ame]
http://www.kyb.com/knowledge-center/...eplace-shocks/
Both Sachs and KYB recommend 50K as an interval for OEM shock replacement. Obviously, they're in the business of selling new shocks, but replacing the OEM dampers at 60-75K is not as early as you'd think it is.
Airlift performance air struts (only struts) RavenFR-Sowner Brakes, Suspension, Chassis 1 11-01-2015 04:51 PM
FS: Stock Struts continuecrushing Brakes, Suspension, Chassis 0 01-08-2014 04:04 AM
WTB: OEM struts KVDB31 Want-To-Buy Requests 4 09-08-2013 09:32 AM
Slotting Struts ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-24-2013 03:08 PM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
