Old 02-15-2016, 05:44 PM   #15
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
Theres a fellow in the GTA selling a set of pro kits with stock struts for 300. Check Can classifieds.
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 02-15-2016, 05:46 PM   #16
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
his are sportline
RickyRacer is offline   Reply With Quote
Old 02-15-2016, 05:48 PM   #17
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by RickyRacer View Post
his are sportline
Still not a bad deal. You can sell off the Sportlines and have a new-to-you set of struts for pennies on the dollar.
jawn is offline   Reply With Quote
Old 02-15-2016, 07:14 PM   #18
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
OP you have a PM
Shameless plug:
I have both stock struts (14k miles) + pro-kit springs for sale $250
and
Koni yellow single adjustable shocks (18k miles) + pro-kit springs for $700
I've loved both setups and now I'm moving up to fully adjustable coilover setup for DD/track duty
If you're interested let me know.
Thanks =)
-Bret
stoked_on_spool is offline   Reply With Quote
Old 02-15-2016, 07:53 PM   #19
FT86Z
Drift noob
FT86Z's Avatar
Sorry I read the post wrong, they are indeed Sportlines and jawn makes a good point
FT86Z
藤原とうふ店
Old 02-15-2016, 08:29 PM   #20
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Needing replacement is a matter of perspective. The internal seals in a strut can and will degrade given enough miles. This can occur without the strut leaking from the body, and it's fairly gradual. 60K is a number that's thrown out there, but you can certainly stretch it longer than that.
Most people only notice that their struts are bad when they're completely blown, since it's a gradual change. That said, I've seen OEM struts completely fail as early as 50K, but that was in a car that lived on fairly rough roads. Depending on your expectations for damping, it's not a bad idea to replace them before they completely fail. I've seen 60K mentioned a lot, but I generally think of anything described by manufacturers as being a "lifetime" interval item needing to be inspected or serviced between 50K and 75K. If you don't care that your dampers aren't performing like new, you can ride it until they're completely blown.
Rule of thumb and anecdotal knowledge =\= OE reccommended replacement interval of 60k, appreciate the description though, very helpful for those who don't understand what we're talking about.
ineedyourdiddly
Old 02-16-2016, 11:52 AM   #21
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I believe the replacement interval of 60k refers to miles so around 100kkms? I've got around 30kkms and I'll be selling them in the spring once my coils are on.
Lynxis is offline   Reply With Quote
Old 02-16-2016, 01:49 PM   #22
wparsons
wparsons's Avatar
Most damper manufacturers suggest ~50k miles (80k km's) for a replacement interval.
As for what parts, I would replace the upper mounts and bearings as well.
flickr
Old 02-16-2016, 03:19 PM   #23
strat61caster
And Jiffy Lube still recommends 3k oil change intervals.
Dampers fail before 50k, after, and right on the dot. Anybody who cares can either afford to replace low end dampers wholesale or have them rebuilt (bilstein's are ~$450 last I checked, and can be revalved if desired) or at the least afford some dyno time to do a health check.
Personally, I wouldn't even think twice about running the OE dampers to >100k miles provided they don't show signs of failure, most road cars sail past that without any deterioration in ride quality. (fwiw my OE dampers with >40k miles on them are perfectly healthy)
ineedyourdiddly
Old 02-16-2016, 03:20 PM   #24
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
unless its 40k track miles
Old 02-16-2016, 03:29 PM   #25
strat61caster
6x track days, ~10x autox events
So less than 1k track miles, but imo that's irrelevant, the dampers will get more of a workout on shitty freeways in ill repair (For anyone in the bay my car has seen probably 20k miles on 101/280/680/80) than on a smooth track.
Edit: Mav put more track mileage on his Ohlins and they dyno'd well at 20k miles:
http://www.ft86club.com/forums/showp...&postcount=212
ineedyourdiddly
Old 02-16-2016, 03:32 PM   #26
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
yeah honestly I see no point in replacing them till they fail.
Old 02-16-2016, 03:33 PM   #27
jawn
jawn's Avatar
Yeah, with how rough the pavement is around here, 50K city miles would be more concerning than track miles.
Airlift performance air struts (only struts) RavenFR-Sowner Brakes, Suspension, Chassis 1 11-01-2015 04:51 PM
FS: Stock Struts continuecrushing Brakes, Suspension, Chassis 0 01-08-2014 04:04 AM
WTB: OEM struts KVDB31 Want-To-Buy Requests 4 09-08-2013 09:32 AM
Slotting Struts ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-24-2013 03:08 PM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
