#15 | |
Drives: 2014 Scion FR-S, 1998 Honda Accord
Sent from my ONE A2005 using Tapatalk |
#16 |
| The Following User Says Thank You to driftking96 For This Useful Post: | Ultramaroon (02-15-2016) |
#17 | |
Best of luck getting it fixed up.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | PandaSPUR (02-15-2016) |
#18 |
Is the throttle body valve opening/plate/cover supposed to be slightly slanted?
#19 |
yes, just a tad and it should not stick. If you turn on the ignition, you should hear the servo buzz and you should hear it operate as you work the throttle pedal.
#20 | |
EDIT: I didnt see the flames before because the throttle body was covered. Sent from my ONE A2005 using Tapatalk Last edited by driftking96; 02-15-2016 at 09:21 PM. |
#21 |
Holy shit did my stock engine just backfire? I just researched and found out that incomplete combustion can also occur through the manifold, previously I thought it was only through the exhaust? I have uploaded a video of my car starting up and at around 20 seconds you can see another really small and quick backfire with a little bit of flames, if I'm not wrong.
EDIT: Video attached inside compressed ZIP file and uploaded on vid.me https://vid.me/GUFD |
#22 | |
Maybe you were fiddling with the throttle while you were cranking it? That's a no-no. edit: ok, saw the vid. I think once you put everything back on, it will run just fine.
#23 | |
#24 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Check that link. The parts diagram for the intake area is up top and it has corresponding part numbers/links so you can buy replacements. EDIT: And this one, more up close diagram of the intake including the MAF: http://parts.subaru.com/a/Subaru_201...10-070-01.html Throttle area: http://parts.subaru.com/a/Subaru_201...10-063-01.html Last edited by PandaSPUR; 02-15-2016 at 11:37 PM. |
| The Following 3 Users Say Thank You to PandaSPUR For This Useful Post: |
#25 |
Drives: 13 Scion FR-S
If plastic bits get past the throttle plate it could potentially interfere with the valve train. I've seen this bend valves and cause a no start condition on a VW. I would do a compression test if possible.
#26 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
Always happy to help. I'll keep following and throw in any more help I can.
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | driftking96 (02-16-2016) |
#27 | |
#28 | |
| Tags |
| cel, engine, stalls |
| Car will not starts at all | Tomahawk | Issues | Warranty | Recalls / TSB | 74 | 02-06-2016 07:32 PM |
| Do e85 cold starts damage engine? | jaorocks1 | Engine, Exhaust, Transmission | 20 | 12-02-2015 05:12 AM |
| Strange beep sound from engine on starts | fanaticalz | Issues | Warranty | Recalls / TSB | 5 | 05-19-2015 01:10 AM |
| jerky starts | goshem | BRZ First-Gen (2012+) — General Topics | 14 | 01-19-2014 11:21 PM |
| Engine doesn't start right away | Cajun | Issues | Warranty | Recalls / TSB | 1 | 02-04-2013 02:09 PM |
