#29 |
Drives: FR-S Whiteout
![]() I went ahead and installed a 52mm prosport EVO gauge in a vent pod. While the included wiring and pressure sender coupled with the gauge pod, the prosport oil galley plug and fuse tap made the instal super clean, the LED light is not quite as bright as I would have liked. Kinda wished I went analog with the gauge. Also the idle oil pressure is scary low at 10-11psi once warmed up..
Intent > Content
cowardice is the mother of cruelty. |
#30 |
#31 | |
![]() It's not half bad in the dark. Matches some of the lights in the car, kind of. ![]() Matches the door lock and power window switch...
Intent > Content
#32 |
Actually, I've seen @Decay107's Defi gauge. It is fast and has a beautiful display.
I love @Lunatic's setup, too.
#33 | |
The defi BF gauge looks like a good match, pricey doe: http://www.defi-shop.com/products/ad...adbf_oilpress/ I kinda wished I went with this one in hindsight: http://prosportgauges.com/amber-whit...ure-gauge.aspx Yes I'm "frugal" with my mods, but I'm still picky.
Intent > Content
#34 |
Inactive
Drives: .
I use the prosport "JDM"series amber/white gauge, was the only one I could find reasonably priced with a sweep/lcd readout. Also would always rather have 60mm gauges.
#35 | |
Drives: 2013 Firestorm FRS
#36 |
Drives: 2016 Halo FRS
Defi BF series are amazing. they have good features as well. auto dimming, adjust the dimming level, set warnings (controller will make a continuous beep when it hits the set warning temp/pressure), check the highest peak values (oil pressure has 2, highest/lowest), reset the peak values, and also you can record up to 2 or 3 minutes i cant remember which, and you can playback the whole session you recorded and watch the gauges and observe
i had the BF series on my S15 in Japan and bought another set again before i came back to the U.S because once you've had them, you wont buy another brand. Although Greddy is coming out with some new ones as well... they look pretty sexy. |
#37 |
It's not good, but not terrible. I'm sure a 60mm pod would be a bit worse.
Intent > Content
#38 |
Drives: Toyota
#39 |
@boomslang are those TRD gauges?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#40 |
Drives: 2013 FR-S Whiteout MT
Where are you guys hooking up the oil temp and pressure sensors? I have an oil cooler and was thinking about buying a sandwich plate to go on top of the oil cooler one..
When in doubt, throttle out!
#41 |
Turning is for Nerds
Drives: 35 characters is not enough
I used the location at the front of the block where the manual specs out the acceptable oil pressure range. I removed the oil pressure switch as it's useless anyway. For temperature, I just use my phone to read from the ECU.
#42 |
| oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 05:46 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
| DIY: mechanical oil pressure gauge | litemup | DIY (Do-It-Yourself) Guides | 14 | 09-06-2014 11:12 PM |
| Have a tire pressure gauge you really like? | Anthony | Tracking / Autocross / HPDE / Drifting | 21 | 09-10-2013 06:09 PM |
