Old 02-13-2016, 03:45 AM   #43
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by FRS Justin View Post
What sound are you looking for, is their anyway to compare it too something. I assume a 2-1/4 to 2.5 inch piping. I will use my stock auto frs for fitment and sound clips. I might even spring for the dyno.
As large as possible, preferably 2.5"+ with similar sound levels to stock exhaust would be for me. Personal preference would be a slightly deeper tone, but tone is secondary to weight reduction, good flow, and overall volume. There are a TON of loud exhausts available on this car but not much for us guys running a full exhaust at tracks with noise regs.
Decay107 is offline   Reply With Quote
Old 02-13-2016, 03:52 AM   #44
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
ACE is building a quiet exhaust, I don't think we need another one.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 02-13-2016, 03:57 AM   #45
Decay107
Decay107's Avatar
It's just an axleback and dual exit, I want something with larger than stock piping, weight reduction, and lower noise. ACE only addresses one of those.
Old 02-13-2016, 05:17 AM   #46
FRS Justin
Drives: 2013 Asphalt FRS
I think anything over 2.5 will kill the torque. I put my 3 inch high flow on with a header and I swear I LOST 20FTLBS OF TORQUE I HATED IT!! But the top end was good. I'm sure the manufacture is well aware of diameters. I'm thinking light weight stainless thin wall.
I will be using a bone stock catted stock over pipe design. Also a Auto trans because of the tighter fit. If it works auto it will definitely work 6sp.
What's the decibel rule so we make sure it complies. Also how much does what you are running weigh,
Any feed back, what's your opinion?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-13-2016, 05:56 AM   #47
churchx
churchx's Avatar
Drives: 2014 GT86
Thin walls may also mean lot of fight with drone with extra weight lost on more of resonators. Everything has cons/pros.
As for loudness - ensure that it will be at reasonable level if used together with catless header, to not need to swap it to another quieter catback if header is upgraded.
OR, add some option to quieten/louden it. Even if not in some advanced way with electrically/mechanically actuated valve & dual exhaust paths, then at least with some optional bolton part.
churchx is online now   Reply With Quote
Old 02-13-2016, 07:12 AM   #48
sam69
Drives: GT 86
Originally Posted by D_Thissen View Post
I'd be interested in functional side vents that look OEM, and a quiet single exit exhaust that doesn't drone.
I'm in the process of making functional side vents atm but they look far from OEM
Had a few mates check em out and had the big thumbs up plus they should pull alot of hot air out as well .
sam69 is offline   Reply With Quote
Old 02-13-2016, 08:29 AM   #49
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by Hyper4mance2k View Post
Bolt-in 4 point roll bar with cross brace and harness bar. FIA legal w/o destroying my car.
^^^This +100
Originally Posted by Joe-G View Post
How about a removable cargo tray for those of us with gutted interiors.. Could be incorporated into the spare tire attachment bolt for securing.. with optional half or 1/4 setup for those with cages. Better yet, something that can fit some wheels/tires, jerry can, jack, tools would be awesome! It just sucks when you have to haul your bins, jerry cans, tools, tires, duffel bags, etc and they slide all over the place.
I had this idea but i have no means of fabricating it.
A nice carpet piece that would cover gutted rear seats.
^^^This This needs to happen. And keep weight in the front of your mind. It shouldn't weigh more than the carpeted piece that covers the spare tire.
My own contribution is a set of knockoff BRZ headlights. Make it look just like the BRZ headlights except without a blinker option. For the FRS guys.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-13-2016, 10:19 AM   #50
Ashikabi
Ashikabi's Avatar
Originally Posted by Takumi788 View Post
^^^This +100
I'm making a rear seat delete with expanding foam(for structure) this spring. I need it to support wheels for race day. I'll try to make a thread for it so keep an eye out. There is also a good looking option from rearseatdelete.com for $300
Old 02-13-2016, 10:30 AM   #51
Dream20b
Y u do dis?
Originally Posted by churchx View Post
* OBD angled connector with on/off switch for multiple wifi modules/OFT and optionally two or more selectable output ports (IIRC they cannot work at same time), so that one can simply switch off OBD devices to not drain battery and so that one doesn't have to damage port with frequent plug in/out.
this.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 02-13-2016, 10:48 AM   #52
celek
Resident Gear Head
celek's Avatar
Oh I got another idea, what about custom badges? I want to replace my toyota badge with a custom one but I cant find any I like. They all look wayyy to cheap and tacky
You must be looking in the wrong place.
This guy makes one off customs what ever you want he is local to me
http://ink361.com/app/users/ig-11020...ete39sp/photos
celek is offline   Reply With Quote
Old 02-13-2016, 04:02 PM   #53
cammyT
Drives: 2015 Scion FR-S
Complete flat underbody
Replacement of rear difusser plastic with a vented/mesh vertical surface and functional diffuser. Allow user to cut out their own exhaust holes. Also have a section for SMALL reverse light (minimal impact on astetics - similar to Rocket Bunny reverse light)
Finally, a 3 inch header back or catback with integraded muffler in front or midpipe. Within Muffler, there's two paths; straight thru 3inch and muffled chamber. Integrated butterfly vavles in exhaust to either send gas thru straight section or muffled section. Both sections should converge to a single exit before axleback. This would ensure that the exhaust exits the same tailpipe/s regardless of whether we're in loud or quiet mode. This would also leave more room for radical diffuser designs, or perhaps those who want the tailpipes to exit higher for a more exotic look.
cammyT is offline   Reply With Quote
Old 02-13-2016, 04:19 PM   #54
cammyT
Can someone sketch up a diffuser design so I have something to take to the table.
Something similar to following
This without license plate of course
Be sure to maintain access to both tow hook threads.
Also integrate a black lip on transition from bumper body to mesh surface. Kinda like the rocket bunny - this should maintain a cleaner look imo
Old 02-13-2016, 04:27 PM   #55
FRS Justin
I have access to mufflers with electric cutouts but they are pricey.
[ame="https://www.youtube.com/watch?v=AP7B_kja1ow"]PPE exhaust sound test 1 - YouTube[/ame]
shows the cutout function but sound quality of clip is bad
710whp
Old 02-13-2016, 08:21 PM   #56
ort895
ort895's Avatar
What about a center exit exhaust bumper/ diffuser.
Kind of like the f type center exhaust. I've been thinking about making the center exit exhaust myself but I can't find any (not tacky) bumpers
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Selling BRZ, parting out parts (STI, Toms, TRD parts) ucsmfu Canada Classifieds 32 09-16-2015 12:17 PM
Edirb racing seats (manufactured by Bride racing) DavidBob Other Vehicles & General Automotive Discussions 7 08-21-2014 01:25 PM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
