Drives: None
Where should my engine load be around idle?
My engine load is sitting around 34 percent while at idle. I'm running an avo turbocharger as well. Is this normal?
Sent from my LG-D850 using Tapatalk |
#3 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
MT or AT ?
edit: I don't know too much about this stuff but that sounds normal-ish to me |
#4 |
Drives: None
#5 |
Drives: None
#6 |
Not Bаnned Anymore
Yeah sure but mine is AT I am not sure if that effects it but I will check afterwork today for you. I will use ECUTEK though as I don't trust the torque app.
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Astroboy (02-05-2016) |
#7 |
Drives: None
#8 |
Just a note, load is not expressed as a percent, but as the amount of fuel going through the engine. So you're not seeing 34%, but 0.34grams/rev. If Torque is displaying it as a percent, I wouldn't immediately trust the value.
For NA, load tends to be around 0.3 at idle and up to 1.4 at WOT.
#9 | |
Not Bаnned Anymore
| Strange noise/vibration under heavy engine load | Panecki17 | Issues | Warranty | Recalls / TSB | 65 | 05-04-2017 07:58 AM |
| Engine Idle... Is this normal? | Premium 615 | Engine, Exhaust, Transmission | 5 | 08-28-2015 12:47 AM |
| Engine idle jumping | Shisui86 | Engine, Exhaust, Transmission | 5 | 06-14-2015 04:07 AM |
| Air temps and impact on engine load | brn12345 | Software Tuning | 0 | 04-30-2014 02:50 PM |
| Engine noise free revving or under load | heeltoe86 | Issues | Warranty | Recalls / TSB | 4 | 04-29-2013 12:58 AM |
