Drives: '15 BRZ Limited
Engine Idle... Is this normal?
Just wanted to say I've already did a
and didn't get anything on my question. Seems that option doesn't work for the Galaxy Note II or tablet. So... I was just at Walgreen's picking up some prescriptions through the drive thru and noticed that the RPMs were dropping to 500 (sounded like it was going to stall) while the car was in park then rebounding to 800-850 kinda like a slow pulsing. I hadn't noticed it before but then again with 2300+ miles on the car I hadn't got a lot of seat time. Is that normal behavior? Is it correctable?
2015 Subaru BRZ Limited AT6 |
Mumbler
Drives: Sensibly
Drives: '15 Halo FR-S
Very normal. Get used to it.
Thanks Tank.
I subbed into the threads so I can get any updates from other members.
Drives: 2013 FRS Whiteout
Just one of the variants of the idle dip, hunting idle we have, normal lol. Mine did it when I had the AC on and coming to a stop in neutral, the rpm's would drop to a near stall then shoot back up to about 900 to stabilize at their usual 600 or so. No dealer reflash has been able to correct this, not even an aftermarket reflash. The majority of us have a higher idle and this helps compensate. Not sure what causes this but maybe load and the ecu not compensating before the change.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#6 | |
humfrz |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 09:40 AM |
| Normal engine sounds | BrianBlueBRZ | Engine, Exhaust, Transmission | 3 | 06-28-2014 12:49 AM |
| Normal engine startup? | NWFRS | Engine, Exhaust, Transmission | 16 | 10-18-2013 03:17 AM |
| Can't decide, is my idle problem or normal? | ultra_frs | Issues | Warranty | Recalls / TSB | 5 | 05-21-2013 02:49 PM |
| Is engine knock normal for the FA20? | Cal3000 | Engine, Exhaust, Transmission | 17 | 05-20-2013 01:12 PM |
