Old 02-05-2016, 01:49 AM   #1
Astroboy
Astroboy's Avatar
Drives: None
Where should my engine load be around idle?
My engine load is sitting around 34 percent while at idle. I'm running an avo turbocharger as well. Is this normal?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 02-05-2016, 10:35 AM   #2
Astroboy
Astroboy's Avatar
Drives: None
Anybody?
Old 02-05-2016, 10:52 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
MT or AT ?
edit: I don't know too much about this stuff but that sounds normal-ish to me
Old 02-05-2016, 12:13 PM   #4
Astroboy
Astroboy's Avatar
Drives: None
MT or AT ?
Mt
Old 02-05-2016, 12:14 PM   #5
Astroboy
Astroboy's Avatar
Drives: None
MT or AT ?
Can you check yours through android torque?
Old 02-05-2016, 12:19 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah sure but mine is AT I am not sure if that effects it but I will check afterwork today for you. I will use ECUTEK though as I don't trust the torque app.
Astroboy (02-05-2016)
Old 02-05-2016, 12:24 PM   #7
Astroboy
Astroboy's Avatar
Drives: None
It is off. Ecutek is better. Please find out. Thanks
Old 02-05-2016, 12:37 PM   #8
phrosty
Just a note, load is not expressed as a percent, but as the amount of fuel going through the engine. So you're not seeing 34%, but 0.34grams/rev. If Torque is displaying it as a percent, I wouldn't immediately trust the value.
For NA, load tends to be around 0.3 at idle and up to 1.4 at WOT.
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
Astroboy (02-05-2016), go_a_way1 (02-06-2016)
Old 02-06-2016, 02:07 AM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
guess that answers your question OP I did take a quick look at one of my logs and it was 0.3ish I honestly forgot to go check after work and just remembered now lol
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 08:58 AM
Engine Idle... Is this normal? Premium 615 Engine, Exhaust, Transmission 5 08-28-2015 01:47 AM
Engine idle jumping Shisui86 Engine, Exhaust, Transmission 5 06-14-2015 05:07 AM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 03:50 PM
Engine noise free revving or under load heeltoe86 Issues | Warranty | Recalls / TSB 4 04-29-2013 01:58 AM
