#29 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Thinking....if it cranks... oe doesn't. ..may be ECU? Fried.
#31 |
Drives: BRZ DGM Limited
When you turn the car to aux without trying to start it, do you get the green flashing key on the dash?
#32 |
Drives: 13 FRS
#33 |
Any Update? Would you be willing to attempt a bump/push start?
I'm gonna do a little reviewing here: We're 60-70 percent sure the battery is alright So that leaves the starter or a lose engine connection or fuel injection driver box possibly?
#34 |
Drives: 13 FRS
Won't be back at the house until Thursday so I'll update once I get home or once the problem gets fixed. If I can't do it myself I hope it doesn't cost much to fix
#35 | |
I thought the OP said that he had replaced the starter ...... of course, it still could be bad. I don't know about these ECU driven engines, but wouldn't it still turn over even if the fuel injection system was screwed up ...... ?? humfrz |
#36 | |
Also with tuning stuff for the main ECU, I know that if you accidentally skip a step in the OFT flash process and turn the key to start the car nothing will happen @steve99 might know what happens there. It usually happens when you press OK one of the last few steps and the car refuses to start till the ignition is turned fully off and back on again. But that's a different ball game.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | humfrz (02-03-2016) |
#37 |
#38 |
Drives: FT86
Thats weird,
The RED key symbol or lock symbol indicates security still active and the key fob not being read by car, no chance car is going to start with the red key needs to go green you have the correct key fob ? , you dont own another toyots/subaru and picked up the wrong ones Hold the key fob next to start button for 30 sec then press start while key fob near start button does the fob lock/unlock the doors |
#39 |
I still think it's something simple like the battery. the fact that the OP's dad didn't actually drive the car as often as the OP thought is really the key factor that leads me to think this. the battery just might not be completely flat so the lights and stuff still come on, just won't crank.
EDIT: or might be a bad/dead fob key like @steve99 pointed out
#40 | |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | FRSBRZGT86FAN (02-03-2016) |
#41 |
Drives: FT86
Its probably best to go back to start and check systematicly
will key fob lock/unlock doors. check car battery ensure clutch fully depressed when trying to start wiggle steering wheel whilw pressing start button to ensure steering lock disengauges make sure key symbol on dash turns green when start pressed else you got no chance if its staying red or lock sybmol is red |
#42 | |
Drives: 13 FRS
2- buying a new battery (optima red top) 3-clutch is fully pressed but still nothing 4- I did wiggle the steering wheel which is weird since I've never had to do that to any other vehicle I've owned. 5- I also have the base of the model so I don't have the fancy push start button 😕👎🏼 Once I get the new battery in I hope it fixes the problem |
| Car only starts when primary 02 is unplugged | j0hnnybk01 | Issues | Warranty | Recalls / TSB | 22 | 08-28-2017 11:13 AM |
| Random tip - cold starts | Dammod | AFRICA | 34 | 09-22-2015 01:38 AM |
| jerky starts | goshem | BRZ First-Gen (2012+) — General Topics | 14 | 01-19-2014 11:21 PM |
| Jerky / shaky starts | Itssrayyxd | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 06-17-2013 01:27 PM |
| Issue: Cold starts | jesseps | CANADA | 7 | 11-24-2012 11:26 AM |
