Old 02-01-2016, 07:33 PM   #29
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Thinking....if it cranks... oe doesn't. ..may be ECU? Fried.
Old 02-01-2016, 08:55 PM   #30
Tomahawk
Drives: 13 FRS
Thanks for serving our country ....
My pleasure. I love what I do 🇺🇸
Tomahawk is offline   Reply With Quote
The Following User Says Thank You to Tomahawk For This Useful Post:
humfrz (02-01-2016)
Old 02-02-2016, 09:21 PM   #31
BRZnut
Drives: BRZ DGM Limited
When you turn the car to aux without trying to start it, do you get the green flashing key on the dash?
Old 02-02-2016, 10:28 PM   #32
Tomahawk
Drives: 13 FRS
Nope I only get the red one
Old 02-02-2016, 11:34 PM   #33
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Any Update? Would you be willing to attempt a bump/push start?
I'm gonna do a little reviewing here:
We're 60-70 percent sure the battery is alright
So that leaves the starter or a lose engine connection or fuel injection driver box possibly?
Old 02-02-2016, 11:36 PM   #34
Tomahawk
Drives: 13 FRS
Won't be back at the house until Thursday so I'll update once I get home or once the problem gets fixed. If I can't do it myself I hope it doesn't cost much to fix
Old 02-03-2016, 01:01 AM   #35
Well, I'm one of the 30% that is not convinced he doesn't have a weak battery.
I thought the OP said that he had replaced the starter ...... of course, it still could be bad.
I don't know about these ECU driven engines, but wouldn't it still turn over even if the fuel injection system was screwed up ...... ??
Old 02-03-2016, 01:29 AM   #36
FRSBRZGT86FAN
Yes in some cases, however I know of some cases with people who installed the Crawford BPBs without the "riser" because the provided instructions were crap. They found it doesn't ground properly with one of the bolts loose and the car would not turn over, other people would have the engine turn over then die immediately.
Also with tuning stuff for the main ECU, I know that if you accidentally skip a step in the OFT flash process and turn the key to start the car nothing will happen @steve99 might know what happens there. It usually happens when you press OK one of the last few steps and the car refuses to start till the ignition is turned fully off and back on again. But that's a different ball game.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (02-03-2016)
Old 02-03-2016, 02:01 AM   #37
Yes in some cases, however ............
Oh, my ....... these machines have left me behind ......
Thanks for the insight .....
Old 02-03-2016, 02:09 AM   #38
steve99
Drives: FT86
Thats weird,
The RED key symbol or lock symbol indicates security still active and the key fob not being read by car, no chance car is going to start with the red key
needs to go green
you have the correct key fob ? , you dont own another toyots/subaru and picked up the wrong ones
Hold the key fob next to start button for 30 sec then press start while key fob near start button
does the fob lock/unlock the doors
Old 02-03-2016, 02:10 AM   #39
ryoma
ryoma's Avatar
I still think it's something simple like the battery. the fact that the OP's dad didn't actually drive the car as often as the OP thought is really the key factor that leads me to think this. the battery just might not be completely flat so the lights and stuff still come on, just won't crank.
EDIT: or might be a bad/dead fob key like @steve99 pointed out
Old 02-03-2016, 02:12 AM   #40
steve99
Drives: FT86
after flash completed you need to switch off ignition to get ecu out of program mode else car wont start, but he has not been "flashing" :-)
FRSBRZGT86FAN (02-03-2016)
Old 02-03-2016, 02:17 AM   #41
steve99
Drives: FT86
Its probably best to go back to start and check systematicly
will key fob lock/unlock doors.
check car battery
ensure clutch fully depressed when trying to start
wiggle steering wheel whilw pressing start button to ensure steering lock disengauges
make sure key symbol on dash turns green when start pressed else you got no chance if its staying red or lock sybmol is red
Old 02-03-2016, 09:26 AM   #42
Tomahawk
Drives: 13 FRS
check car battery
1- key fob unlocks doors (I have a tundra but the keys are completely different and the battery in the fob is brand new)
2- buying a new battery (optima red top)
3-clutch is fully pressed but still nothing
4- I did wiggle the steering wheel which is weird since I've never had to do that to any other vehicle I've owned.
5- I also have the base of the model so I don't have the fancy push start button 😕👎🏼
Once I get the new battery in I hope it fixes the problem
Car only starts when primary 02 is unplugged j0hnnybk01 Issues | Warranty | Recalls / TSB 22 08-28-2017 11:13 AM
Random tip - cold starts Dammod AFRICA 34 09-22-2015 01:38 AM
jerky starts goshem BRZ First-Gen (2012+) — General Topics 14 01-19-2014 11:21 PM
Jerky / shaky starts Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2013 01:27 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
