Old 02-02-2016, 10:28 AM   #1
Eldari
Drives: BRZ Limited
Leaking valve stem - Warranty?
My rear passenger side tire is leaking about 5psi a week and I'm fairly sure it's leaking from the valve stem. Would this be covered under the 3 year warranty? It's not a huge hassle to refill it every other week or so, but it has grown old after a few months.
Eldari is offline   Reply With Quote
Old 02-02-2016, 10:46 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
at GM (where I work) those would be covered under the base warranty, however if its a bead leak or something else then be ready to pay to have it fixed.
Tcoat (02-02-2016)
Old 02-02-2016, 10:50 AM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Indeed. I'd check for a small nail first, since punctures are not covered.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Tcoat (02-02-2016)
Old 02-02-2016, 03:41 PM   #4
I'd suggest you call your dealership and ask them.
They may be in a generous mood and fix it for you.
Personally, I'd just stop into a auto repair/tire shop and have them find and fix the leak.
If when you spray some soapy water around the valve stem ..... you see bubbles ..... then the leak is at the stem.
However, like @jawn speculates, my money would be on that you have a small puncture in the tire.
Tcoat (02-02-2016)
Old 02-02-2016, 05:42 PM   #5
shellslinger
Drives: Whiteout FRS
Going with the crowd here. I think it may be a small puncture.
shellslinger is offline   Reply With Quote
Old 02-02-2016, 05:52 PM   #6
KL
Drives: 2013 SWP BRZ
sub'd. I have a similar issue with a winter tire on stock rim. After having changed the valve, sanded the rim and reseated the bead, I still have a leak. Haven't gotten around to the soapy water but I don't care too much either.
Curious what your problem ends up being but I'd be pretty surprised if you got a warranty fix.
KL is offline   Reply With Quote
Old 02-02-2016, 06:15 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Short answer: no
Long answer: read the warranty booklets. No.
Works Valve Stem & RS-R Lug Nuts xDBOYx Wheels and Tires 7 11-29-2014 05:23 PM
RPF1 OEM Valve Stem Question pf330ci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-22-2014 09:18 PM
Questions about Valve Stem Fitments Stayreal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2014 04:25 PM
Are your valve stem caps safe? qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-18-2013 01:32 AM
Can this valve stem be rebuilt? ayau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 12-24-2012 02:57 AM
