Old 12-23-2012, 06:09 PM   #1
ayau
Drives: Some rust bucket
Can this valve stem be rebuilt?
The inside of this non-TPMS valve stem is hollow. Is it possible to get them rebuilt at a tire shop, or do I need to buy a new valve stem kit?
Old 12-23-2012, 06:12 PM   #2
whaap
whaap's Avatar
It's not so much a case of "rebuild" but rather just a matter of replacing the valve core. Any auto supply store should have what you need.
whaap is offline   Reply With Quote
Old 12-23-2012, 06:14 PM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
It's hard to tell from the picture, but I'm assuming the stem is snapped off? If so I think you're out of luck. If it's attached to a TPMS sensor you'll probably need to get a whole new unit.
If its just a plain valve stem without a sensor they're cheap, just replace it.
Old 12-23-2012, 06:16 PM   #4
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Hard to tell from the pic. But it looks like they just took the valve out of the stem. This is the easiest ways for the guys to deflate the tires before dismount, mount, balance etc.
They should be able to plug a new valve in there. no worries. If not, it's a simple swap to a new one.
Beyer Subaru is offline   Reply With Quote
Old 12-23-2012, 06:18 PM   #5
ayau
The stem looks good, but the "core" is gone. It just looks like a hollow valve stem.
The reason I want to use these is because they're metal. I think most tire shops only carry rubber stems.
Old 12-23-2012, 06:23 PM   #6
ayau
I took another picture showing the valve stem.
Old 12-23-2012, 06:52 PM   #7
Beyer Subaru
Yep. Your good. Any tire shop can drop a valve in there. All you need is threads on/in the stem.
Old 12-23-2012, 06:53 PM   #8
OrbitalEllipses
Drives: Attitude
Man those ARE dirty ayau. Prosoco 600, remember!
Old 12-23-2012, 08:46 PM   #9
neutron256
neutron256's Avatar
Or just pick up a valve kit and do it yourself. Most auto parts stores have them.
Old 12-24-2012, 02:57 AM   #10
Chupacabra
'it's the yeti of Texas'
Chupacabra's Avatar
Drives: 2013 Whiteout 6MT FR-S
I've heard ayau likes it dirty.
BRZerhood & FR-Society
Chupacabra is offline   Reply With Quote
Ferrea's Valve components for FRS/BRZ Sportsguy83 Engine, Exhaust, Transmission 44 05-09-2014 08:46 AM
DIY Antenna Stem Removal ninjasaurusrex DIY (Do-It-Yourself) Guides 18 01-29-2013 10:35 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 09:10 PM
Valve Timing/Computer miss paula Issues | Warranty | Recalls / TSB 3 09-20-2012 03:27 PM
Testing a Rebuilt Engine Exage Other Vehicles & General Automotive Discussions 0 04-29-2011 09:42 PM
