Old 01-31-2016, 07:51 PM   #1
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
Fluterring sound after header and op install
So i recently installed the 1320 performance uel header and op. After the install we took it for a drive and noticed a really annoying fluttering kind of sound. We tried the soapy water test and couldn't find anything. I also am using new oem gaskets. Does anybody know where the noise could possibly coming from? And how much on average would a muffler shop charge me to get this leak fixed?
Heres a drive by video of the sound, increase volume if you don't hear it.
"Power is nothing without Control"
j2digit is offline   Reply With Quote
The Following User Says Thank You to j2digit For This Useful Post:
coconutboy (03-22-2020)
Old 01-31-2016, 08:22 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Sounds normal-ish to me. You don't mean the UEL header burble, do you?
The only other thing that I hear is a slight rattle, which could be from running the stock catback (if you're running the stock catback), or maybe from the overpipe contacting the frame.
jawn is offline   Reply With Quote
Old 01-31-2016, 08:32 PM   #3
j2digit
j2digit's Avatar
Running an aftermarket catback. Its that rattling noise that you hear is what is really annoying. Its possible for the overpipe to be in contact with the frame which could be causing that sound? Ill have to check that out.
Old 01-31-2016, 08:35 PM   #4
jawn
jawn's Avatar
Yeah, check to see if there's any rub/wear marks on the overpipe. You can get a little bit of adjustment going if you disconnect the front pipe from the overpipe.
The other thing I'd look at is if the header is touching the skid plate.
The Following User Says Thank You to jawn For This Useful Post:
j2digit (01-31-2016)
Old 01-31-2016, 08:37 PM   #5
j2digit
j2digit's Avatar
Alright thanks for the suggestions! I am truly a noob when it comes to putting car parts on.
Old 02-01-2016, 11:22 AM   #6
xsl27x
Drives: 2015 Scion FRS, Firestorm
I just put on the same header/op combo. Sounds exactly the same. Checked for leaks, nothing. Using grimmspeed gaskets. Just how it sounds...
Sent from my LG-D800 using Tapatalk
xsl27x is offline   Reply With Quote
The Following User Says Thank You to xsl27x For This Useful Post:
j2digit (02-01-2016)
Old 02-01-2016, 12:50 PM   #7
JB86'd
JB86'd's Avatar
Drives: JAWS
There's multiple threads on this already and it's been answered. If you've tested for leaks and there aren't any, what you're hearing is the exhaust flow because of thinner metal, no heat shield, no cat.
It's normal, enjoy your header
JB86'd is offline   Reply With Quote
Old 02-01-2016, 01:52 PM   #8
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Seems like only some headers do this though. My Tomei doesn't make that noise at all.
Luftwaffel is offline   Reply With Quote
Old 02-01-2016, 03:55 PM   #9
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
FWIW, I have a tomei uel with stock overpipe and had a leak due to my overpipe flange being somehow warped.
It made fluttering sounds before as well as the annoying ticking sound upon accelerating.
tried whatever I could to tighten and replace gaskets and put high temp sealant on the gasket. It still leaks a little but I'll just replace the overpipe and front pipe in a few months when I save up some monies
mike7792 is offline   Reply With Quote
Old 02-01-2016, 04:42 PM   #10
JB86'd
JB86'd's Avatar
Drives: JAWS
Thats true, I think someone said that Tomei uses thicker, heavier gauge steel, which would help mask that noise.
Old 02-01-2016, 06:07 PM   #11
j2digit
j2digit's Avatar
You have any sounds clips?
Old 02-01-2016, 10:19 PM   #12
mike7792
mike7792's Avatar
No i don't sorry
My only suggestion is if you're worried like I was, is to just take the car into the shop and ask to see what they can do to fix the leaks
Old 02-04-2016, 10:22 AM   #13
nunyo
Drives: 2013 Scion FRS 10-series
Ive just installed the same parts (1320 UEL header and 60mm OP). The car already had a Borla catback. I love the rumble out the back, but I'm not loving the high-pitched flutter sound. It does seem to be a 'feature' of the thinner walls, lack of heat shields, etc.
I think I'll take a swing at wrapping the header in hopes that it will dampen the ringing sound of hot gas slamming against the inner walls of the tubing. If that doesn't work, my 1320 UEL will be available in the for sale section soon.
nunyo is offline   Reply With Quote
Old 02-05-2016, 01:54 AM   #14
j2digit
j2digit's Avatar
let me know how the wrap goes!
ticking sound with el header install. fluffy-reindeer-slayer Engine, Exhaust, Transmission 10 05-11-2021 01:13 AM
My incomplete sound install Moe AFRICA 10 05-27-2014 08:52 AM
My Install from Simplicity in Sound jlu Northern California 4 06-08-2013 10:20 PM
My Install from Simplicity in Sound jlu Electronics | Audio | NAV | Infotainment 3 06-05-2013 05:24 PM
GT Sound Matt Install Neilus Scion FR-S / Toyota 86 GT86 General Forum 0 12-18-2012 06:32 AM
