Old 01-30-2016, 11:57 PM   #15
steve99
Drives: FT86
Originally Posted by merdok12 View Post
The car only has 1100 miles on it but I've been noticing a very subtle rattling noise when I put my foot on the throttle. Is it just a BRZ internal part making noise and I'm not used to it? Or should I go to the dealer?
Only modification is Valenti tail-lights.
Are you running 93 fuel, if you running less than 93 like 91 or 89 it probably engine detenoation or knock
Old 01-31-2016, 12:05 AM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
While not commenting on the original poster's situation, I'm in Illinois exclusively running 93 octane Shell V-Power NiTRO+ Premium and the rattle is present for me at all times right off of idle.
RJasonKlein is offline   Reply With Quote
Old 01-31-2016, 12:22 AM   #17
wbradley
Sarcastic SOB
wbradley's Avatar
I agree with load on engine at low RPM.
Old 01-31-2016, 09:14 PM   #18
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I seat belt clip on the driver seat makes a rattle when I use it. Drives me nuts! So I don't buckle up and the noise is gone. the seat belt chime only bugs me for the first 30secs or so and then it stops.
As the cops say
Click it or Tic... run!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-12-2016, 03:49 PM   #19
LostSalad
Drives: Toyota 86 - Charcoal Grey
As the cops say
I know this is a thread necro, but it's still 2016 so I consider the corpse to be at least... partly fresh.
If anyone finds this from Google (like I did) - please wear your freakin seatbelts. I had the same rattle and squeak coming from my seat belt clip and it drove. me. mad.
A bit of lubricant sprayed onto the bolt where it is attached fixed that right up. Just sayin.
LostSalad is offline   Reply With Quote
Old 09-12-2016, 05:14 PM   #20
eggroll
Drives: Scion FRS
I somtimes hear rattling coming from the rear when driving in rough roads. What could it be? My trunk space is empty and nothingg seemed to be loose in the spare tire compartment
eggroll is offline   Reply With Quote
Old 09-12-2016, 06:54 PM   #21
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I've learned that rattles in Subaru's are just a "feature"
Seriously though, could be something loose in the rear deck. I've had something metallic sliding around since I got the car. Never made the time to take it all apart to search for it!
Subaru STI :
Old 10-25-2016, 05:28 PM   #22
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by shaynek View Post
make sure your rearview mirror is properly mounted and tightened. i had some rattling issues with that.
This just popped up after 3 years 42k miles. How did you tighten it good sir?
Frishkorn is offline   Reply With Quote
Old 10-25-2016, 05:58 PM   #23
Phothiraj
Drives: Lightning Red BRZ
I also once had a rattling from my interior and later on noticed it was coming from my gearbox under acceleration. might just be the reverse lockout making the noise
Phothiraj is offline   Reply With Quote
exhaust rattle stock
Loud Rattling Noise at Start Up tomaszjanczak Issues | Warranty | Recalls / TSB 43 09-18-2014 08:50 PM
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 12:34 AM
Rattling noise at the rear. Not uniform, but happens often. ZeHeadBanger Issues | Warranty | Recalls / TSB 7 10-22-2013 09:48 PM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
