Old 01-27-2016, 12:07 PM   #15
Hagbard
Hagbard's Avatar
The Middle one im using is the Innovatemotorsports MTX Its Pressure and Temp,
The Numbers Look wierd but its just the Photo and Timing Some Lights look off. I do have more than 2PSI Oil Pressure
Hagbard is offline   Reply With Quote
Old 01-27-2016, 01:06 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Lunatic: loving how stock-ish result ended. Not much lost from placing in that space anyway, as with keyless system and start button it's too narrow for modern smartphones, and usb-aux ports can be relocated to glovebox (way i'd prefer, to not tempt thieves with something plugged in in usb in clear sight).
Old 01-27-2016, 01:31 PM   #17
renfield90
The Stig's German cousin
Where'd you get that gauge holder? Does it orient the gauges towards the driver? Thanks.
Old 01-27-2016, 01:35 PM   #18
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by Lunatic View Post
I made a gauge pod out of aluminum and installed three 2 1/16" gauges. Oil Pressure, Boost, and Tranny Temp. Mine works really well except it's scary how low oil pressure gets at idle.
nice! I've been looking to do something very very similar
Old 01-27-2016, 03:11 PM   #19
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
What happens to a passenger if your airbag goes off?
Decay107 is offline   Reply With Quote
Old 01-27-2016, 03:16 PM   #20
Hagbard
Hagbard's Avatar
Yes they are angled i the holder towards the driver have no problem with them and they have a programed Flashing if they hit a certin temp that would be easy to spot.
And i got it from rallysport direct its an ATI Triple Meter Dash Pod 60mm can probly get it most places
The Following User Says Thank You to Hagbard For This Useful Post:
renfield90 (01-27-2016)
Old 01-27-2016, 03:17 PM   #21
Hagbard
Hagbard's Avatar
Air Bags Actually in the top of the dash so nothing would happen if you remove that panel behind it is actually sold and empty.
The Following 2 Users Say Thank You to Hagbard For This Useful Post:
Decay107 (01-27-2016), JazzleSAURUS (02-18-2016)
Old 01-27-2016, 03:19 PM   #22
Decay107
Decay107's Avatar
Old 01-27-2016, 03:32 PM   #23
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
You could put your weed in there (to quote Adam Sandler).
I have never figured out why they didn't make a REAL glove compartment with all of that extra space.
I should make a locking gun safe to fit in there.
justatroll is offline   Reply With Quote
Old 01-27-2016, 03:41 PM   #24
Decay107
Decay107's Avatar
I don't need to hide my weed, because Oregon
A locking gun safe on the other hand...
The Following User Says Thank You to Decay107 For This Useful Post:
justatroll (01-27-2016)
Old 01-27-2016, 04:17 PM   #25
Ashikabi
Ashikabi's Avatar
If you have to unlock it... what's the point? It's too late by the time you get it open
Old 01-27-2016, 05:25 PM   #26
justatroll
justatroll's Avatar
There are many places that you cannot carry (even with CCW permit) and this forces people to leave their guns in their car while they go into the courthouse, post office, etc.
Of course this is dangerous if you do not have a gun safe in your car.
If you need to get to it quickly, leave it unlocked...
The Following 2 Users Say Thank You to justatroll For This Useful Post:
Old 01-27-2016, 05:27 PM   #27
Ashikabi
Ashikabi's Avatar
I like you. I was hoping you would say this instead of: Im fast enough! I don't keep it loaded either, just in case it goes off
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 01-27-2016, 08:48 PM   #28
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Thank you.
Lunatic is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 01:48 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
DIY: mechanical oil pressure gauge litemup DIY (Do-It-Yourself) Guides 14 09-07-2014 12:12 AM
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 07:09 PM
