Old 01-23-2016, 07:59 PM   #1
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Is there any issues with buying a used OFT?
I installed a catless header and have thrown a CEL so I figured it's time to get a tune. Is there absolutely any downfall to buying an used OFT just to save some bucks?
wise345 is offline   Reply With Quote
Old 01-23-2016, 08:01 PM   #2
Jonathanlim
Drives: 15' Frs
Nope. Just make sure they un-marry it from their car.
Jonathanlim is offline   Reply With Quote
The Following User Says Thank You to Jonathanlim For This Useful Post:
wise345 (01-24-2016)
Old 01-23-2016, 08:41 PM   #3
wise345
wise345's Avatar
So no risk in it not working on mine?
Old 01-23-2016, 08:45 PM   #4
Jonathanlim
Drives: 15' Frs
As for tune wise no. On open flash's website you can get free off the shelf maps for life.
Old 01-23-2016, 08:50 PM   #5
wise345
wise345's Avatar
Sounds awesome I'll pick one up
Old 01-23-2016, 09:39 PM   #6
Jonathanlim
Drives: 15' Frs
Read up there is lot of useful information. http://www.ft86club.com/forums/showthread.php?t=71157
Old 01-23-2016, 09:41 PM   #7
Spectre20
Spectre20's Avatar
Drives: 2013 BRZ Limited
Do it. I just bought one used and everything is working great. I'm running the basic stage 1 93 octane map, it it made a pretty noticeable difference. Can't wait to get some headers and start running E85.
Spectre20 is offline   Reply With Quote
The Following User Says Thank You to Spectre20 For This Useful Post:
Old 01-23-2016, 10:59 PM   #8
Teseo
Drives: frs
Cons are unknown fingerprints
The Following 2 Users Say Thank You to Teseo For This Useful Post:
Lord09 (01-24-2016), wise345 (01-24-2016)
Old 01-23-2016, 11:55 PM   #9
wise345
wise345's Avatar
Will it be required to run a flex fuel kit to run e85? Or just the E85 map?
Old 01-23-2016, 11:57 PM   #10
Jonathanlim
Drives: 15' Frs
No just the e85 map. Only bad thing about e85 is that it is hard to start in the winter. A lot of people switch over to 91/93 in the winter. But I heard there is a flex fuel kit in development.
Old 01-24-2016, 12:00 AM   #11
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
No flex fuel kit needed. Just run the 93 down to almost empty tank fill up e85 and flash. Drive normal for 15 min. Let the fuel trims get adjusted and you should be good.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Old 01-24-2016, 01:24 AM   #12
steve99
Drives: FT86
follow proceedure here
http://www.ft86club.com/forums/showthread.php?t=67310
for winter mod the cranking pulse width tables for better cold starts as per above link and you can also add some petrol if your on high ethanol e85 to aid starting as well
Old 01-24-2016, 01:32 AM   #13
wise345
wise345's Avatar
My supra runs E85 and i just didn't know if the FA20 needed a flex fuel kit for some reason. Thanks guys!! I'll pick up an OFT soon!
Old 01-24-2016, 01:38 AM   #14
wise345
wise345's Avatar
Doesn't delicious tuning make one?
Buying an FRS hello86 Scion FR-S / Toyota 86 GT86 General Forum 3 03-26-2014 05:53 PM
If you are buying a BRZ how old are you? blackmist27 BRZ First-Gen (2012+) — General Topics 205 03-07-2013 09:18 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 05:18 PM
Help with buying a BRZ in NJ/NY ft86Fan NY / NJ / CT / PA 6 07-01-2012 07:19 PM
Why I am buying a BRZ BMWDAD BRZ First-Gen (2012+) — General Topics 37 01-01-2012 10:01 PM
