Old 11-21-2015, 05:15 PM   #15
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by Dino451 View Post
Crank Shaft bearing failure confirmed. Engine is in pieces.
Is it a rod bearing or a main bearing?
The rod bearing is the one on the crank at the base of the rod, while the main bearing is the one in the block which holds the crank in place.
I would guess it is a rod bearing, as that is the one that would make noise as the rod hit back and forth on it.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 11-21-2015, 05:35 PM   #16
Update: I just got a call and the SA said they found a bad crank rod bearing?.
I take this as rod bearing at the crankshaft. Haven't yet heard of a spun main on this engine.
Old 11-21-2015, 05:38 PM   #17
Dino451
Dino451's Avatar
Drives: Scion FRS/Whiteout/OEM spoiler
It was a rod bearing, at least that is what I was told on the phone. I never got to talk to the tech working on it, just the SA but he later said crank shaft bearing. There might be some confusion but I will pick the techs brain when I go pick up the car.
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
Dino451 is offline   Reply With Quote
Old 11-21-2015, 07:16 PM   #18
FirestormFRS
Crankshaft bearing is a main bearing. Connecting Rod Bearing is a rod bearing.
FirestormFRS is offline   Reply With Quote
Old 11-21-2015, 10:50 PM   #19
BRZnut
Drives: BRZ DGM Limited
Yet another engine failure!! Is the dealer covering the cost of this?? Or trying to place the blame on you?
Old 11-21-2015, 11:12 PM   #20
Oh ya we must be up to a grand total of about 20 on here now (non modified, FI or tuned) it is an epidemic!
Ultramaroon (11-21-2015)
Old 01-20-2016, 08:14 PM   #21
Dino451
Dino451's Avatar
Update: After I got it back in mid December I had it for two weeks before a even louder rattle appeared. I took it in the week after Christmas and it was diagnosed with a damaged crankshaft bearing.
Dealer said there was debris in the oil pick up and that they would order all new crankshaft bearings and that it might be ready end of the week last week.
Not sure what happened between that time but I was told yesterday I will be getting a new shortblock
Hopefully I will be getting my 86 back soon.
This was after the first repair
[ame="https://www.youtube.com/watch?v=OFPW0OS2_5I"]FRS crankshaft bearing failure - YouTube[/ame]
Old 01-20-2016, 08:16 PM   #22
Dino451
Dino451's Avatar
The dealer gave me no push back on any of my claims. My car only has a TRD intake. I haven't spent a single dime on theses repairs luckily. It seemed too easy to be honest.
The Following User Says Thank You to Dino451 For This Useful Post:
Ultramaroon (01-20-2016)
Old 01-20-2016, 10:12 PM   #23
BRZnut
That's great to hear for a change!
Old 01-20-2016, 11:41 PM   #24
pantdino
When the bearing failed it probably damaged the crankshaft too.
Rattle when i turn off the engine Subforever Issues | Warranty | Recalls / TSB 11 08-18-2015 01:22 PM
Toyota/Subaru D4S "engine cover" rattle canadaRS1.0 Issues | Warranty | Recalls / TSB 4 06-14-2015 07:12 PM
Engine rattle MacJunkie AFRICA 12 04-01-2015 07:12 AM
engine rattle mrnibbs Engine, Exhaust, Transmission 11 06-05-2014 09:17 PM
Engine pinging (rattle noise) under acceleration sho AUSTRALIA 95 08-10-2013 05:52 PM
